Please help: Shift issue
Old Apr 28, 2014 | 05:32 PM
FTLEVO18's Avatar
GUYS,
Im new to this board and would just like to thank anyone and everyone for helping out in advance with my issue.
I have a 2006 EVO MR and everything was fine with the car until i let it sit for a while ( i know its a coincidence ) and then the care started making a very off noise when it was in neutral, a pretty loud rattle / clanking. Once the clutch pedal was depressed the noise when away completely. A day later i fired up the car and the noise subsided a bit however it was still running in the background. If you pulled the shifter just a hair, the noise changed and went away.
I then tried to drive the car and that was a no go. Now it won't let you let the clutch out without stalling ( even in neutral ). The shifter shifts through the gears however 2 and 6 are a little tough to get into. Even with the car up in the air without a load on it, the clutch can't be released even in neutral. The car will boog and stall like its in a gear.
Any incite??
TurboTylerIX
21
Dec 19, 2017 11:16 AM
iwantevonow
May 18, 2015 08:51 AM
Malfury
Mar 18, 2015 05:57 PM
Icegod87
Sep 24, 2014 04:48 PM
mdosu
Aug 27, 2014 08:32 PM
