Transfer Case Torque Specs
Old May 5, 2014 | 10:52 AM
seanl5447's Avatar
Question Transfer Case Torque Specs
I purchased a transfer case for my 2005 evo 8. When i got it it was in 2 pieces. The pinion gear housing i guess is what i would call it was separated from the rest of the case so that i could inspect the ring and pinion gear. I now need to put it back together for installation and i cant find the torque specs for the 7 bolts that reconnect the shaft to the rest of the assembly. Any help would be greatly appreciated. I will post pics shortly to better explain what im looking for.
Also if anyone knows if the metal and rubber gasket need to be replaced or if they can be re used since they're in good shape.
-Thanks
Old May 5, 2014 | 12:17 PM
ReidFletcher's Avatar
It's 17ft/lbs. I reused the oring when installing wavetrac, it was very hard finding a replacement and the ring wasn't damaged.
Old May 5, 2014 | 01:16 PM
seanl5447's Avatar
awesome thanks!
sonicnofadz
Aug 2, 2017 10:48 PM
SloEvo12
May 4, 2016 08:53 AM
desertsoldier22
Feb 17, 2016 08:51 AM
dillon410021
Sep 27, 2014 07:55 PM
Evo478
45
Mar 2, 2012 08:46 AM
