Torque Solutions propeller shaft bushing squeak
I just installed the torque solutions drive shaft bushings & now I have a squeak I was wondering if anyone else ran into this problem?
Everything has been installed correctly. The donut part of the bushings went on top against the chassis, the Abe Lincoln hats came from the bottom. I didn't reuse the one washers & everything is tight. I also reinstalled the small heatshield tightly & it doesn't rub, although the sound I am getting sounds like a metal rubbing together.
I mainly hear it when I take off in first from a stop uphill & when my rear suspension goes over bumps. I'm 90% sure I've centralized the sound to the center drive shaft around the bushing area.
Has anyone else encountered this? Thanks
I'm dont mind the nvh at all if this squeak is normal, ill just try greasing them. I would just like to know if others experienced the same.
I have the Torque Solutions driveshaft support bushings. They do transmit more drivetrain noise, but not a squeak like you are saying you have. It sounds like you have a heatshield rubbing somewhere.
The extra drivetrain noise & the slight hum at 3k I'm completely fine with, it just the squeak sounds pretty bad. It definitely sounds like that but everything looks good & remains untouched except that little one. The only things i changed were the bushings.
VMC216007
Apr 6, 2015 09:53 AM
MarriedToSubaru
Dec 25, 2014 05:06 PM
600RR
Jun 3, 2014 05:15 PM
MrEvoVIII
May 23, 2006 08:45 PM
