HELP!! changing out cv axles.
Old Jun 6, 2014 | 02:36 PM
seirralynn's Avatar
Okay. So I'm trying to replace my front cv axles. But my axle won't come out. From what I've been reading it should be able to come out with out a problem. Unless I did something wrong somewhere. I have a 2005 evolution rs. Please help a little lady out!
Old Jun 6, 2014 | 02:56 PM
egis's Avatar
You can't pull it out from tranny side?
Old Jun 6, 2014 | 02:59 PM
seirralynn's Avatar
No. It won't budge.
Old Jun 6, 2014 | 03:29 PM
Terror Rising's Avatar
Get yourself a set of prybars. They don't just fall out.
Old Jun 6, 2014 | 03:40 PM
seirralynn's Avatar
I've been at it with prybars for hours. Maybe I'm not strong enough to budge it. :'(
Old Jun 6, 2014 | 03:45 PM
SilverShadow03's Avatar
EvoMoto.com has a nice write up...
EvoMoto How To
Start at #21 - #25
Hope this helps!!
Old Jun 6, 2014 | 03:53 PM
seirralynn's Avatar
Finally got it. I'm surprised I was even being able to drive.
Attached Thumbnails HELP!! changing out cv axles.-forumrunner_20140606_175206.jpg   HELP!! changing out cv axles.-forumrunner_20140606_175225.jpg
Old Jun 6, 2014 | 03:58 PM
seirralynn's Avatar
Now I just have to put the new back in -.-
Old Jun 6, 2014 | 04:01 PM
Good job!
Follow the instructions on the link I provided (just read further down for the install instructions unless it give the usual 'Reverse the process to install' comment)...should give you some tips and tricks to get it back in ....
GL!
Old Jun 6, 2014 | 04:07 PM
dsm nexus's Avatar
Out of curiosity did you do anything in particular to cause that kind of damage?
Old Jun 6, 2014 | 04:21 PM
seirralynn's Avatar
No. Previous owner. Tried running the car into the ground and blowing it up. He finally admitted to it recently.. it a project. And now my transfer case won't stop leaking. Any ideas how to quick fix that?
Old Jun 6, 2014 | 05:22 PM
05OrangeSS's Avatar
You probably ripped the seal putting it back in, or taking it out I'm assuming.
Old Jun 6, 2014 | 05:33 PM
seirralynn's Avatar
I have no clue. But one of my good buddies are coming over to get a better look at it and hopefully tell me I did something wrong and it can be fixed.
Old Jun 7, 2014 | 10:12 PM
egis's Avatar
Do you have any updates ? Btw I like your pink gym shoes.
Old Jun 8, 2014 | 05:56 PM
seirralynn's Avatar
My update is my axle still isn't done. We ended up getting some pretty severe weather and required safety. But will be going back at it tomorrow. Also the axle will go in. But not all the way. We have taken it out of gear, and put it in every gear to see if that would help. Cause I read that somewhere it could help. And still no such luck. So my tcase fluids are just pouring out. And thank you
Cody Corey
Jan 3, 2016 03:07 PM
Technical10
Jun 3, 2015 07:52 AM
jason42003
Mar 10, 2015 12:45 AM
FoxFister
Jul 17, 2010 08:30 PM
