Compression test results and few questions
Hi fellow members
I did a compression test on my stock block evolution 8 today. The numbers were 170 in all cylinders except one which came to 160. The motor has about 20k miles on it and I am running a Precision 6262 turbo kit making around 500whp.
I have no blowby or spark plug problems.
1. Should I be worried about one cylinder having a lower number?
2. Can a stuck lifter cause a lower compression test number on one cylinder?
Thanks
Thanks
Cylinders should be within 10% of each other. That one cylinder at 160 is not concerning. Do a wet compression test and see what you get. A stuck lifter would give you no compression in that cylinder as it would hold the valve open.
Hi fellow members
Thanks
Thanks
lostsoulsevo
28
Feb 9, 2017 05:52 PM
