GSP 70mm Throttle Body Question
Hey guys. Installed my gsp tb today. But my question is, the tb has no nipples for the coolant hoses. Soo how will the iacv function without the temp reading from the coolant ? Also, initial start up the car idles at 2800rpms. Help.
https://www.evolutionm.net/forums/ev...some-help.html
Why you need all this if you already know? Or you just having fun?
hafa adai,
You don't need the coolant lines living on Guam.
I see yours is idling at 3K. Did you adjust the speed idle screw or on aftermarket ones tend to have throttle cable adjustment screws. Deactivate the iscv and set the base idle after warmed up. Then reconnect it. Should be decent after that. Probably need a tune too. GL.
hafa adai,
All due respect, for the other gentlemen speaking in brackish tones, if you pay attention to the date/time stamp, my post on the other thread was after I made this post. If you want to help a fellow enthusiast, then help. Otherwise, dont toss up your useless remarks that accomplished nothing for you and nothing on my car.
Cheers.
EvoCop
Evo X How Tos / Installations
14
Jul 11, 2015 11:09 AM
XK120
Sep 10, 2008 11:15 PM
