wastegate won't fit on turbo right
Old Jun 29, 2014 | 02:03 PM
3gevoclipse's Avatar
This is how much it is opening at full pressure
Old Jun 29, 2014 | 03:22 PM
I don't think k you can preload if the arm is too long
Old Jun 29, 2014 | 05:27 PM
I found something new- the hot side has 78-13010 115 stamped in. I think this means it is a 10.5 hot side. Correct me if I am wrong.
Old Jun 29, 2014 | 06:41 PM
Faisalm's Avatar
I think that's a 9.8 hotside
Old Jun 29, 2014 | 07:44 PM
Then I don't know why it won't fit. Its going to a machine shop tomorrow to get shortened
Old Jun 29, 2014 | 08:53 PM
sparky's Avatar
That is not an VIII actuator. Probably it is a IX WGA.
Old Jun 29, 2014 | 09:05 PM
victorevo8's Avatar
anyway you can take the v band off and take a picture of the front side of the turbo.
Old Jun 30, 2014 | 07:01 AM
I will get a picture when it comes back today
Old Jun 30, 2014 | 07:06 AM
heel2toe's Avatar
It doesn't matter if its a 9.8 or 10.5 hotside. You have an IX WGA and need an VIII. Do not hack up the turbo. Instead pick up the correct WGA (VIII) and call it a day.
Old Jun 30, 2014 | 09:45 AM
egis's Avatar
Or buy kinugawa 25psi wga for $120 for the future.don't spend your money for machine Shop just yet.
Old Jun 30, 2014 | 10:26 AM
cmspaz's Avatar
This.
It's pretty obvious that's the issue.
Old Jun 30, 2014 | 10:57 AM
heel2toe's Avatar
^Lol Im sitting here reading the thread thinking wtf!? Forget bending the arm, forget the machine shop, just forget it!!!
Remember even if you get the WGA to "fit" you may still ring into issues with the flapper wont sealing properly killing spool, not opening fully causing boost creep issues and lastly not able to be properly preloaded also killing spool.
Pick yourself up a VIII WGA; it will be cheaper and will save you the headache down the road.
Old Jun 30, 2014 | 08:23 PM
I don't spend l money at the shop I use, my shop uses them a lot so we usually just walk in and use the tools. We machined the actuated rod to match the evo 8 wga. Shortened the length, re threaded and matched the bends of the 8's. Tested it on the turbo and everything seems to work fine as far as flapper seating and opening smoothly. If it doesn't run right I'll swap it over to an 8. I appreciate all the help. I eventually will use a 21 psi wastegate, but that will be when I shell out the money for some internals during school
Old Jun 30, 2014 | 09:14 PM
sparky's Avatar
Now that we qot that out of the way, lets go ahead and set preload. Unless you have something bettter to do.
Old Jul 1, 2014 | 09:51 AM
cmspaz's Avatar
In b4 OP clocks the WG arm for preload instead of adjusting the actuator rod, because free machine shop access.
