wastegate won't fit on turbo right
Old Jun 29, 2014 | 07:50 AM
3gevoclipse's Avatar
Hello I am finishing up my build and I am having issues with the wastegate fitting in the turbo correctly. I have an evo 8 turbo and wastegate. When I try to put it on it sits at a little angle and has the wastegate partially open. The arm on the turbo was bent in shipping and I bent it straight and still no luck.
Old Jun 29, 2014 | 08:47 AM
When I finally get them to match up, the wastegate flap is open
Old Jun 29, 2014 | 09:14 AM
This seems to be the only way I could get it to fit with the flapper closed (last pic)
Old Jun 29, 2014 | 09:29 AM
ak47po's Avatar
Congrats!
Old Jun 29, 2014 | 09:54 AM
victorevo8's Avatar
were you able to figure it out?
Old Jun 29, 2014 | 10:17 AM
Not really, if you look in the last pic there is only 1 bolt that is in. I tested the wastegate and it opens and closes OK, or it seems, for just 1 bolt. it doesn't pivet around. I guess I will try and if it gives me problems I'll try again
Old Jun 29, 2014 | 10:25 AM
victorevo8's Avatar
thats a 8 turbo right? do you have a picture of the front side maybe its a 9 with a evo 8 actuator which wont work if i remember correctly i think its a little shorter
Old Jun 29, 2014 | 10:47 AM
Its a 8 turbo, td05hr 16g 9.8t. The problem actually seems that the wastegate is too long, and the turnbuckle is already at the bottom
Old Jun 29, 2014 | 10:49 AM
victorevo8's Avatar
so maybe you have the 9 wastegate? since that one is longer than the 8
Old Jun 29, 2014 | 12:45 PM
But I thought the 9 was shorter. I checked out the serial number and it is supposedly an 8 anybody know an easy way to check?
Old Jun 29, 2014 | 12:55 PM
victorevo8's Avatar
no evo 9 wga is longer
Old Jun 29, 2014 | 01:38 PM
Really? Would it work the way I have it, if I drill another hole to stop it from moving? It seems to open the wastegate flapper about half way, I will get a picture of it open to see if you think it is enough to work
Old Jun 29, 2014 | 01:51 PM
3K's Avatar
3K
Did you try turning the whole wastegate arm? Take the eye out of the flapper connector and turn the whole arm around till it lines up.
victorevo8's Avatar
did you already preload it?
Old Jun 29, 2014 | 01:53 PM
I did try turning the whole arm and it got close but didn't line up completely. I Have read about preloading but I don't really follow how to do it. I dont seem to be able to press the arm into the actuated at all
