help oil jets under pistons
Old Jul 4, 2014 | 09:25 AM
mr evo7's Avatar
Hey guys recently had my engine blown up by a bad tuner.
I have got everything I need to assemble the engine but I noticed my oil jets (sprayers are crank due to piston hitting them.
One has completely broken off.
I am not able to get oem oil jets for another 8 weeks.
Is there any other oil jet that could work or anything I can do to replace these jets
I prefer keeping the oil jets as I daily drive the car
85mm wiseco 2.3 pistons 9.0.1
Eagle rods
4g64 crank
Pte 6262
Old Jul 4, 2014 | 05:12 PM
okevolutionVIII's Avatar
I'm using the exact same parts as you and after bending the tubes to clear the crank, I had 2 break due to vibrations. Just blocked them off as they are only needed for the OEM cast pistons and haven't had any problems.
Old Jul 4, 2014 | 06:26 PM
94AWDcoupe's Avatar
yeah you can remove your oil cooler too its not needed either.
Ef8b16
50
May 8, 2017 08:56 AM
bsphillips
19
Sep 23, 2016 08:06 AM
real fast
Apr 15, 2016 05:28 PM
real fast
Feb 9, 2016 06:59 PM
BLKCarbonEVO
14
Aug 21, 2009 08:09 AM
