How much does boost.....
Old Jul 11, 2014 | 06:06 PM
superkizuna's Avatar
Forum,
Does increasing boost significantly lean AFRs? I haven't noticed anything but I want to ask any pros trolling out there. Also, if it does and say the ECU goes to comp for the lean condition how much IDC past 99% can the stock injectors go before they are useless. I know they are scaled a bit lower for buffer but is all the buffer necessary?
Old Jul 11, 2014 | 06:45 PM
CT9A PR's Avatar
Seems to me like you either need larger inj.
What cc inj, fuel pump and fuel would be nice to know.
Old Jul 11, 2014 | 07:09 PM
Stock injectors but I have a walbro fuel pump. Just saving and researching injectors now. I'm going to get them just want to make sure I get the right size for my goals. I'm almost at 400 hp.... so close. That's all I want to hit and then it's all cosmetics from there
Right now I'm at 370 hp; (I know the sig says 360 lol) I'm hesitant to increase boost until I I'm sure that I can go into that buffer I mentioned that is of course unless more psi will not do anything to my afr. I'm doing 11.1 at redline.
Old Jul 11, 2014 | 07:19 PM
RussellDaniel's Avatar
Buy some Fic High Z 1100's, those would be great for what your wanting to do. On 93 Octane you could get away with some 770's, but personally the 1100's are a great injector.
Old Jul 11, 2014 | 10:29 PM
oscarquinones's Avatar
I got PTE 1200 the work very good.
Old Jul 11, 2014 | 11:02 PM
egis's Avatar
Increasing boost by let's say 2-3 psi you wont see significantly lean afr but 5 or more it will lean out.i have 1000 cc my idc was 105% at 30 psi.
Old Jul 12, 2014 | 04:28 AM
How long did you run it like that?
Evo_Jay
Feb 7, 2007 07:21 PM
gunzo
50
Oct 30, 2006 03:31 PM
