Timing 2.4 - Stock gears
Old Jul 20, 2014 | 05:26 PM
xRoguex's Avatar
Just wanted to double check that it was done right...
I have adjustable I might put back in -- but was this done right?
2005 Evo 8 - with 4g64
Attached Thumbnails Timing 2.4 - Stock gears-dscf6394.jpg   Timing 2.4 - Stock gears-dscf6391.jpg   Timing 2.4 - Stock gears-dscf6392.jpg
Old Jul 20, 2014 | 05:38 PM
silver9mr's Avatar
it looks like it may be 1 tooth to many. mine has 18 teeth between timing marks
Old Jul 20, 2014 | 05:47 PM
xRoguex's Avatar
I love when people represent timing a motor based on numbers of teeth. Its so nice.
I thought I was the only one that did it that way.
Old Jul 20, 2014 | 08:35 PM
batty200's Avatar
I have 17 teeth between the marks on mine I believe. Subaru actually has marks on the belt for all the pulleys. So much better. I wish Mitsubishi did that. I may count them out and Mark some belts. It would be 100x's easier.
Old Jul 20, 2014 | 11:59 PM
4g63Moon's Avatar
Yes the timing is good
Old Jul 21, 2014 | 07:51 AM
evolve_VIII's Avatar
The timing looks ok. You should use a piston stop for the crank and not the mark. The 2.4 has more dwell time at TDC.
You will need adjustable gears to place the cams back to the marks on the valve cover. Looks like a 1/2 tooth to the right.
Old Jul 24, 2014 | 09:57 AM
silver9mr's Avatar
you will also find out if its right if you do a compression test. if the timing is off than the compression will be off.
Jseda845
Mar 31, 2016 05:49 PM
Superdan101
Feb 23, 2016 08:59 AM
hutch959
11
Dec 28, 2015 05:23 PM
Javier F.
Aug 17, 2014 10:19 PM
Ct9aGsR
19
May 17, 2008 12:04 PM
