want to put a 3bar or 4bar map on evo 6
Old Aug 1, 2014 | 09:39 PM
CT9A PR's Avatar
Its not plug in and play
How do I do this
Old Aug 1, 2014 | 09:45 PM
Faisalm's Avatar
How do I do this
You have to tap into the wiring harness, can't remember what Pins you need to use, but I think it may be similar to the Evo 8 one.
Old Aug 2, 2014 | 02:11 AM
CT9A PR's Avatar
will be running it with an evo 8 ecu if I do this....
Might use the E6 ECU will like to know eitherway
Old Aug 2, 2014 | 03:21 AM
hashaam81's Avatar
This is what I used on my jdm evolution 8 MR. It comes with a 3 plug ecu and no map sensor from factory.
Pin 42 +5v
Pin 46 Chasis ground
Pin 92 Signal
Old Aug 2, 2014 | 10:40 AM
foxbat's Avatar
Map sensor to E6 ECU
Signal to pin #75
Ground to pin #92
+5V to pin #81
nickleo373
Mar 23, 2016 10:35 AM
MisUnderStood
20
Jan 18, 2016 05:57 PM
fugiwara
Sep 4, 2015 08:20 AM
philamthebest
34
Nov 9, 2010 03:34 PM
kirkklau
Dec 27, 2008 03:13 PM
