EVO 8 Need Help
Old Aug 3, 2014 | 10:44 PM
EvonessOz's Avatar
EVO 8 Need Help
Hi Guys
I have an Evo 8 GSR, 6spd 2003.
So plan is to beef up my tcase and rear diff. Have been looking for weeks now and it seems I have bought the wrong evo.
Should have bought an RS huh!
Anyway, I guess what I'm looking to do is an RS conversion on my GSR as the options to beef up my ayc rear diff seem to be limited to NONE. Any details on what is needed for the conversion would be appreciated. I'm in Australia and finding it hard to find anyone who knows what they are doing.
Thanks guys
Old Aug 3, 2014 | 11:30 PM
Faisalm's Avatar
Originally Posted by EvonessOz
Hi Guys
Thanks guys
For the tcase you'll need to delete the pump and ACD ECU to install the mechanical front diff.
The driveshaft length differs from AYC to non-AYC I believe, so that will need to be changed as well.
Old Aug 5, 2014 | 12:14 AM
EvonessOz's Avatar
no one else has any info for me?
Old Aug 5, 2014 | 06:35 AM
3v0luti0n's Avatar
See if you have any luck with doing a straight trade for an RS
Old Aug 5, 2014 | 04:28 PM
EvonessOz's Avatar
Wow! This has been real helpful. Thanks guys!
Old Aug 5, 2014 | 07:29 PM
Biggiesacks's Avatar
This site is mostly US and we didn't get any CT9A's with AYC so experience here will be limited. What mods are you trying to do that will be limited by your drive train?
Old Aug 5, 2014 | 11:59 PM
EvonessOz's Avatar
@Biggie - Power mate!
Going to push for 400 awk next year. Do not wanna blow a tranny/tcase/diff evertime I take it to the track or strip.
Thank you for your reply .
Old Aug 6, 2014 | 03:04 AM
Faisalm's Avatar
Your drivetrain is more than capable of holding 500+ ft/lbs, even with an AYC diff and ACD diff.
Your only Achilles heel would be your 6 speed transmission as they're known to collapse at around 400+ ft/lbs.
There are two solutions to the 6 speed as I see it:
1- Replace it with a 5-speed.
2- Purchase the modified 6-speed gear set from ShepTrans as they are rated at 650 ft/lbs, which is more than sufficient.
Other than your transmission, you're fine, and obviously you'll need a better clutch if you want to start making power.
Old Aug 6, 2014 | 08:37 AM
bettsbanger's Avatar
I'd also replace all bushings that hold your diff/tcase to ensure longevity and increase the sturdiness of your setup. The less those parts bang around, the less likely they are to fail.
Old Aug 6, 2014 | 10:57 PM
EvonessOz's Avatar
Bushes done the week I bought it.
Thanks for your input guys
dw cuz
Feb 15, 2015 08:09 AM
yeven_stas
24
Feb 9, 2015 07:04 PM
NERO_NOVA
Apr 11, 2010 12:34 AM
maximusnz
Sep 28, 2009 05:52 PM
MalibuJack
62
Mar 30, 2005 03:23 PM
