Evo 9 dying in 5th after WOT pull
Old Aug 8, 2014 | 03:51 AM
mrm95's Avatar
So whenever im doing a pull in 5th and i let off and push in the clutch the car dies. Its done that 3 times now. This bugs me because i feel like it could damage the turbo if its in full boost then having the car shut down right after leaving the turbo spinning with no oil running to it. Anyways, what could cause this issue? and after only 3 times is it likely that i could have done damage to the turbo? Thanks
Old Aug 8, 2014 | 08:03 AM
X Double Dot's Avatar
Could be your idle control valve settings. The way I understand it is this valve (and the ecu settings) have taken the place of the vacuum actuated dashpots that used to be used on older cars. If uve never seen one, it basically makes it so the throttle plate doesn't slam shut immediately when you let off the throttle as this could make the engine die. Are ur idle control valve setting stock still? Also...will this happen in any other gear? Does the engine almost die anytime u go from wide open to fully letting off (with the clutch pushed in).
As for damage to the turbo, it's definitely not extending the life of it lol...but I'd think u should be OK as there is a decent amount of oil in the line etc.
Old Aug 8, 2014 | 08:05 AM
bphx123's Avatar
go see tony at UMS. He will sort you out.
Old Aug 8, 2014 | 10:53 AM
mrm95's Avatar
Yeah i figured it was something to do with the IACV. and that ive noticed, it only does it in 5th. and yeah hopefully only doing it those few times didnt cause any damage to my turbo.
hooliganSKATE
Jul 16, 2015 06:21 AM
ODUB
27
Jan 27, 2014 08:10 PM
vinNybXx
17
Nov 8, 2011 11:05 AM
EvolutionVIIIrs
Dec 29, 2010 09:33 AM
wrxedout
Jan 29, 2008 03:06 PM
