Clutch failure
Old Aug 8, 2014 | 10:51 AM
Rom's Avatar
Rom
Clutch failure
Hi all,
A few days ago my clutch failed and I was unable to engage gears any more. I could get it in gear with the engine off, but not with the engine running. The clutch pedal and hydraulics were working fine (i.e. the slave engaged the fork), but the pressure plate wouldn't disengage.
The shop took it apart today and told me that the TOB was pinched in to the pressure plate, so now I need to replace both. The clutch only has 5000 miles on it, and is an ACT HD clutch kit (installed in November). The TOB was the ACT one (not OEM).
Any ideas how this could have happened, or if anyone has seen this before? I will be heading to the shop later today to take a look at the damage myself...
Thanks!
S.
Old Aug 8, 2014 | 11:08 AM
SilverShadow03's Avatar
What type of clutch do you have? Pull or push style? Pick up an ACT Monoloc....if you have a pull type pressure plate.
http://www.advancedclutch.com/blog/a...type-clutches/
Old Aug 8, 2014 | 11:38 AM
Rom's Avatar
Rom
Yes, it's a pull type... Here's a pic of the TOB...
If I use the Monoloc, should I stick with an ACT TOB, or still use OEM? Any drawbacks to OEM?
Thanks!
S.
Old Aug 8, 2014 | 11:50 AM
Yup..Monoloc more than likely would have prevented that (it was designed to prevent failures like this, if I'm not mistaken). I don't know of any drawback to using an OEM TOB with this basic upgraded clutch.
Get an OEM TOB...I too used the ACT TOB and regret it. SOOOO loud now on deceleration. I'll be using an OEM TOB when I replace this ACT clutch...
Old Aug 8, 2014 | 11:52 AM
BTW, you have a nice collection of cars in your stable! Post up some pics of your rides!
fireroasted
13
Jan 13, 2016 04:35 PM
Pal215
May 17, 2011 10:53 PM
antilag_200
19
Apr 21, 2010 06:02 AM
EVOLV3D
17
Nov 2, 2009 04:39 AM
EVOLV3D
May 21, 2009 06:46 AM
