if A high flow cat flows almost 600cfm, how much does a cat delete flow?
Old Mar 11, 2004 | 02:49 PM
EvolvedfromaWRX's Avatar
any body? this is the random tech one im talking about
Old Mar 11, 2004 | 03:09 PM
spoolinEVO8's Avatar
Nice mods list Josh!
We gotta meet up and talk UTEC one of these days.
Ken
Old Mar 24, 2004 | 07:10 PM
SoR's Avatar
SoR
bump
Old Mar 24, 2004 | 07:43 PM
Pitbul09's Avatar
Not sure on the random one, but al did a dyno test between the UR test pipe and the UR high flow cat and the difference was 5 whp more for the test pipe.
Old Mar 24, 2004 | 08:39 PM
SoR's Avatar
SoR
Hm, so far I've managed to find this thread. It was for a 2.5" random tech. Wonder how it would look like with a 3" he promised to test
https://www.evolutionm.net/forums/sh...threadid=37340
Old Mar 25, 2004 | 09:44 AM
erioshi's Avatar
I think it depends on where you are starting from. With a stock trubo the restriction would probably be less noticeable than with a turbo that pushed more volume. I think Vishnu found removing the cat to be worth about 30(?) HP on a heavily modified car with cams plus a bigger turbo.
Old Mar 26, 2004 | 06:21 PM
shiv@vishnu's Avatar
But on a more reasonable set up (stock turbo, full exhaust, cams, etc,.) removing a free flow cat and sticking in a test pipe usually yeilds about 15whp and 15-20lb-ft of torque. Or at least this has been the trend. Cat delete/test pipes make power, no doubt. If only they weren't so stinky and illegal ($2000 on the spot fine here on the west coast!).
Cheers,
shiv
Old Mar 27, 2004 | 06:16 AM
hmmm we are installing the turboxs cat delete tonight. so i guess we'll see what kinda power a full turboxs turbo back makes (basically a stage 2 car) on the dyno hopefully next week or so.
Old Mar 27, 2004 | 04:58 PM
1QWKEVO's Avatar
be sure to take picturs of the exhaust and delete pipe. I've been debating on modding my Evo or just leaving it stock... I don't need a modded car right now just a reliable one that is fun to drive. But i would like to add an exhaust just to help out on the feel of the car and looks.
How well do the simulators or race pipes promissing no MIL work? Shivs your thoughts and opinions on someone looking to mildly mod the evo as fax as the cat aspects.
Old Mar 27, 2004 | 05:17 PM
SilverEvo8owner's Avatar
Mod your EVO.
If you want a stock car that will be reliable, use your STI.
They are hell to mod, but good stock.
overdrive1
14
Aug 16, 2015 08:26 PM
phantomwilson
Jan 28, 2011 11:34 AM
twinturbozs
11
Mar 21, 2007 02:31 PM
NYEVO8
20
Oct 29, 2003 12:23 PM
