Need a 4G64 head gasket that supports high HP
Old Feb 19, 2015 | 09:34 AM
  #31
rodent's Avatar
Originally Posted by TwStDeVo
Rodent,
Which gasket did you end up going with? Were you having trouble with a certain gasket before making this thread?
To everyone that recommended Cosworth, which one did you go with, 1.3 or 1.5mm thickness?
I went with OEM Evo 9, 5 layer, bored out to spec from Buschur. Its the only gasket I feel safe using without o-ringing the block/head running more than 40psi. I'm glad someone started to make these available again. For me to do it, it requires a trashed 2.4 block where they bore it out more than 87mm and a 4g6x torque plate at a good machine shop.
The Cometic gave out in all cylinders and was pushing coolant. Last pass I did at Bandimere was the worse. I actually have deep scars in the head from the HG failing. Luckily the head can be saved from re-surface.
Old Feb 19, 2015 | 10:51 AM
  #32
JohnBradley's Avatar
The OEM five layer will torch around 38psi from experience. The issue is more likely head and deck than headgasket. Prep is everything, then new studs, a tune that isnt pushing the envelope, etc. I ran no O-ring and 40psi on a Cometic, Atif ran O-ringed and a 7175 at mid 40s so I know that a cometic will work.
Old Feb 19, 2015 | 02:04 PM
  #33
NSDQ's Avatar
Nevermind.
Old Feb 19, 2015 | 09:24 PM
  #34
rodent's Avatar
Which OEM HG is everyone running 40+ psi then? The 3 layer Evo 8?
My head was surfaced at the best head shop here in Denver and very smooth. Block was also surfaced properly and very smooth. Before this motor, my last 2.0 held 43psi no problem with the OEM gasket but I'm not sure if it was the 8 or 9 gasket.
This is the head following the Cometic failure.[/URL]
I circled the 4 areas where it let go. The spot on the right was the worst.
Old Mar 2, 2015 | 12:47 PM
  #35
Mauricio Evo IV's Avatar
Yesterday I blow my cometic head gasket, in my 2.1 destroke 4g64 with only 32-33 psi with a 6266 turbo.
I´m looking a Cosworthhd or better choice, and OEM like you said.
The question is: Where can I buy it or with who can I contact for made the deal...
I will preciate your help man!
Old Mar 2, 2015 | 01:52 PM
  #36
rodent's Avatar
Contact Nick at Buschur. I actually bought 2 bored out OEM gaskets but I may sell one for what I paid if anyone needs one quicker.
Old Mar 3, 2015 | 03:12 AM
  #37
tscompusa's Avatar
I bought three of the OEM modified for my customers. I run the Cosworth FSL in my 2.4 with 87mm bore. I've had it up to 810whp + around 38psi and no issues.
I'll probably push it close to 900 this year to get a really fast MPH.
I wont touch the cosworth HG as long as it does me good. I am also Oring'ed with the head.
That seems to help a lot when you begin to really turn the boost up.
Old Mar 3, 2015 | 02:06 PM
  #38
A 2.0L on an OE headgasket is fine. A 2.4 on a bored headgasket can be completely different story.
Something in the combo and/or tune wasnt right and the car had migrated past knock to pre-ignition. See how the space between the intake valves has no carbon and the outside edges of the valves are clean? The cylinder on the end, appears to be #1, even has a torch mark to the left of the sparkplug.
Again, knowing how far we have pushed the Cometic, I dont think this was just a gasket issue.
Aaron
Old Mar 3, 2015 | 02:19 PM
  #39
rodent's Avatar
Thanks Tom!
Something in the and/or tune wasnt right and the car had migrated past knock to pre-ignition. See how the space between the intake valves has no carbon and the outside edges of the valves are clean? The cylinder on the end, appears to be #1, even has a torch mark to the left of the sparkplug.
Aaron
Trust me, the tune actually on the conservative side and was done by someone who knows what he's doing.
How do you explain others blowing Cometic? Most everyone that has pushed a good amount of HP, hates them for not holding up.
Old Oct 10, 2015 | 09:52 PM
  #40
Macaroni's Avatar
Bumping an old thread:
I've blown out my cosworth on my 10.5:1 2.1L within probably 15-20 pulls. Non o-ringed.
Old Oct 13, 2015 | 02:55 AM
  #41
shmagi's Avatar
using cometic 1.3mm on 10.5:1 30psi
Old Oct 13, 2015 | 08:00 AM
  #42
2006GSR's Avatar
2.4 regular rod. 9.5cr. Non oringed. 28 psi. 700 whp 6765. Je proseal head gasket. Roughly one k miles. Gets beaten every time I drive it.
evolve_VIII
444
Dec 16, 2020 08:11 PM
FRSport.com
Evo 'For Sale' Engine Internals and Drivetrain
Mar 16, 2017 10:47 AM
bigturboevo03
41
Feb 11, 2017 09:57 PM
2006GSR
18
Nov 28, 2016 07:29 AM
4ukc
Oct 10, 2015 11:04 PM
