Zero PSI
Old Sep 24, 2014 | 09:13 PM
Dvolution's Avatar
Zero PSI
Backed over a weird curb and bent the j-pipe on the turbo and lost all boost. New j-pipe, gasket, and OEM intercooler pipes and still no boost. Boost test showed no leaks. Is my turbo done?
Old Sep 24, 2014 | 10:45 PM
jbuhrman's Avatar
Is it possible you pulled a vacuum line that was your boost gauge reference?
Old Sep 25, 2014 | 07:20 AM
Ev0ikon's Avatar
If there is no funny noise and the turbo cartridge spins freely your leak is elsewhere.
Old Sep 25, 2014 | 08:51 AM
Dvolution's Avatar
No power so its definitely not the line to the gauge. Must be the turbo if the system holds pressure. Crap.
Old Sep 25, 2014 | 02:59 PM
slowsrt4:('s Avatar
try pulling your turbo, I hope it was an OEM turbo because they can be replaced fairly cheap. maybe a good time to upgrade
Old Sep 25, 2014 | 04:26 PM
antij0sh's Avatar
Is your wastegate stuck open ? Check the actuator arm and related componenets . check to see if the compressor wheel spins freely.
DrivelineSales
May 13, 2010 02:35 PM
Sam@DriveLine
Evo 'For Sale' Suspension / Brakes / Handling
43
Jan 8, 2009 02:19 PM
warpedminds
Lancer Aftermarket Forced Induction Tech
12
Aug 11, 2005 02:46 PM
Evo11V
Apr 18, 2003 03:07 PM
