Should my wastegate actuator have a hole in it?
I have a stock Evo 9 wastegate actuator and I recently put an O2 dump on. Driving the car today I noticed what sounded like the wastegate fluttering pretty violently. So I pulled the actuator to attempt to tighten the preload a bit. When I flipped it over I noticed the hole in the picture. Looking at the forge replacement on STM there is a set screw in that hole and the hole on mine is clean and looks drilled. So I was wondering if that hole should be there or if I need to close up the hole? Thanks for the input.
Yes I just swapped back to it with this head rebuild. I thought maybe it might be that but I wasn't sure as the tune hasn't been finished just running a base map, so I was trying to cover all my bases mechanically before I blamed the tune.
If you mean you just switched back to a 3-port then that's definitely the sound you're hearing. It's not tune related, it's how the 3-port sounds.
I had that fluttering racket when I installed the 3 port "interrupt" style like 95% of users install them but when I did a "bleed" style routing, the flutter is gone and everything in the boost curve is smooth and consistent.
evoterp
Jan 29, 2014 11:32 AM
D-VO
Sep 6, 2012 08:17 AM
hlm
Jun 16, 2010 08:10 AM
EE
11
Jun 16, 2008 08:16 PM
DSMEVO15
22
Mar 14, 2007 05:53 AM
