Stock frame ff and 3 port
Old Oct 1, 2014 | 05:26 PM
wasabisnooter's Avatar
I bought the toxic fab ff kit and ef4. I'm making the switch to sd and running grimspeed 3 port. My j pipe doesn't have the nipple coming off where the one vacuum line use to go on the stock set up. Does anyone know where i run the vacuum lines for the grimspeed this way. I already looked at the 3 port pdf on how to install and it doesn't explain this.
Old Oct 1, 2014 | 05:48 PM
Boost Demon's Avatar
Veteran: Air Force
Drill a hole in the j-pipe and put a barbed fitting in as a boost source. Use teflon tape and RTV to seal where metal meets metal, should be fine.
Old Oct 1, 2014 | 06:25 PM
Thanks for the input. Ate you going to fl2k next week?
Old Oct 2, 2014 | 07:55 AM
Veteran: Air Force
I'll be working for most of it, so I may see if I can make it out on Friday, thanks for letting me know.
Old Oct 2, 2014 | 04:43 PM
slowsrt4:('s Avatar
I'm so upset that I can't go to FL2k this year... should be a blast
Old Oct 2, 2014 | 04:48 PM
slowsrt4:('s Avatar
and I haven't seen many evos around Lakeland, I'm from Sebring and always pass through Lakeland on my way to Tampa
Old Oct 7, 2014 | 04:25 PM
Hmu, the next time you roll thru 8033971903 or look me up on fb. BRANDON FRANSTED
Evolution7GSR
11
Aug 21, 2015 01:42 PM
Craig King
26
Feb 2, 2013 08:38 PM
Evo3573
36
Jul 21, 2011 07:46 AM
330racing
Jan 2, 2007 04:44 AM
