T3 S200SX: GSC S1 or S2?
Old Oct 6, 2014 | 08:51 AM
signo28's Avatar
Hello everyone, I have a Evo9 Fullrace with a T3 turbo kit with S200SX turbo, stock block, now in third gear I have 14psi at about 4000 \ 4200 rpm and I would spool faster; how can I do?
I put the cams but what do you recommend, S1 or S2 for faster spool? DD or the machine is mainly uphill races.
I accept all the advice ...
P.S. in the future I will have a 2.3 or 2.4L!
Old Oct 6, 2014 | 05:14 PM
JohnBradley's Avatar
Cams wont make it spool faster necessarily but it generally wont hurt. The S1s are normally 30-35whp over stock cams on a stock turbo. The next upgrade with the S2s can be 45-50whp over stock cams really easy. In your case the S2 will give you the most out the top and once the turbo is lit and should be the minimal loss down low.
Old Oct 7, 2014 | 01:06 AM
signo28's Avatar
ok thanks john, I would like something that increases the mid-range torque
RS200
Oct 5, 2015 09:08 PM
arco
Jun 4, 2014 07:25 AM
42revoincali
Dec 6, 2012 06:08 PM
Ben@AGP
Sep 14, 2011 01:52 PM
EvoAnthony
Feb 26, 2007 10:06 AM
