need help with evo 9 mr
Old Oct 7, 2014 | 06:40 PM
acmontero29's Avatar
I just boght the evo 9 mr and i think the clutch went bad but im not sure, can some please helpe with this? Gears started poppin out until one last time and now none of the gears work. Is it a bad clutch pr tranny?
Old Oct 7, 2014 | 07:06 PM
Biggiesacks's Avatar
I believe popping out of gears means its your transmission. As for being locked out of gears it could be either, but probably transmission as you have that first symptom. Either way you should be prepared to replace the clutch if they will be pulling of the transmission.
Old Oct 9, 2014 | 09:37 AM
AJCaron12's Avatar
So you're unable to shift into any gears? Or the vehicle won't move at all when in gear? Check your slave cylinder, check your clutch pedal adjustment. Also check your transmission fluid level, transmission fluid condition, and for metal on transmission drain plug.
Ricekiller1
Northeast Region
Apr 1, 2012 01:51 PM
Earthen
23
Jul 22, 2010 06:43 AM
skold
For Sale - Part Outs
Jul 5, 2007 04:35 AM
Kwman
21
Jul 14, 2005 07:34 AM
evo'skickass
13
Mar 11, 2004 03:28 AM
