No Start Help, Replaced Crank Position Sensor
Old Oct 19, 2014 | 02:33 PM
sk8terdude929's Avatar
So my Crank Position Sensor went bad, i wasnt getting power to the fuel pump and no spark. Replaced the Crank Position Sensor and it started right up for about 30 seconds then it shut down and wont start back up. I am now getting power to the fuel pump and fuel to the fuel rail but not getting spark again. Has anyone ever had issues after replacing the Crank Position Sensor? Could another sensor have been wiped out?
Old Oct 19, 2014 | 02:43 PM
AJCaron12's Avatar
Did you buy an OEM Mitsubishi sensor? Or a downtown one?
Old Oct 19, 2014 | 02:56 PM
OEM and the sensor is still showing good, also getting power to the fuel pump now which i wasnt before the sensor. Its strange since it started for about 30 seconds
Old Oct 19, 2014 | 03:00 PM
galantman03's Avatar
check to make sure your getting power to the coil packs. If you have 12 volts sitting at the coil packs, but no signal, your not going to fire the coil packs. You could also check your ignition fuse
Old Oct 21, 2014 | 05:57 PM
How do I test if it’s getting a signal? It is getting 12V at the coil pack, I also just put in a new Cam Position sensor today but that didn’t fix the issue. Any help would be greatly appreciated
Old Oct 21, 2014 | 06:04 PM
kpr's Avatar
kpr
disable the anti-theft before wasting more money. Thats usually the cause
Old Oct 21, 2014 | 06:54 PM
The stock anti-theft? The immobilizer is currently disabled if that’s what you mean. Please let me know as I’m willing to try anything at this point. The weird part is it ran for about 30 seconds after installing the crank position sensor. Also thank you
Old Oct 21, 2014 | 09:09 PM
AJCaron12's Avatar
Have you removed, inspected, and re-installed your crank sensor again?
Old Oct 21, 2014 | 09:15 PM
just meter at the coil pack pin for voltage. I can't remember what the value is but it jumps on the meter, then you know your getting signal to the ecu to generate spark.
Old Oct 22, 2014 | 11:35 AM
I have and it is still working properly, also before installing the new Crank sensor I was not getting power to the fuel pump. I am now getting power to the pump and fuel to the fuel rail.
Old Oct 22, 2014 | 11:38 AM
I will try that today, there are 3 wires going to the coil pack plug. when starting i am getting power to 1 wire and the other 2 are grounded. I will check what the voltage is and re post. Also thank you to everyone posting as i am dead in the water right now and really need help. THANK YOU
Old Oct 22, 2014 | 11:48 AM
one is power to the coil, one is ground for the coil. The other pin is signal to fire the coil. check all three. do you have a schematic for the evo?
Old Oct 22, 2014 | 01:43 PM
I do not have a schematic, if anyone wants to post one I would appreciate it. So while it's cranking only one of the 3 pins gets power the other 2 stay grounded. Does that mean I'm not getting a signal from the ECU?
Old Oct 26, 2014 | 04:30 PM
stefenboy's Avatar
Did you do a spark test to make sure you are not getting spark?
Old Oct 28, 2014 | 10:05 PM
Yes and i am not getting spark, i am getting power to the coil but no spark.
