When to upgrade fuel system?
Old Oct 19, 2014 | 06:54 PM
Seidelly's Avatar
So I am currently in the last phase of my build..
2.3 Bored 4g63 Block
Cp 9.5.1 Pistons
Manley Turbo Tuff Rods
Forged eagle crankshaft
GSC S2 Cams, 274/274
GSC Beehive retainers/springs
GSC No tick lifters
Manley Valves
ACL Rod/Main Bearings
ARP Head studs
ARP Main studs
Balance Shaft Delete w/ AMS Delete kit
ETS intercooler pipes with intake
Tial BOV (non rec)
3" ARK exhaust with 3" downpipe
AMS intercooler
Exedy Triple
Walboro 255
FP Black BB
Ported stock manifold
Heres my question..
How long with the 255 Suffice?
When will I need more/bigger pumps.
Fuel rail
Fuel lines?
Am I good for 500whp on pump now ?
I would like to get the fueling taken care of before we start tuning and run out of fuel..
I did a bit of searching but i was still undecided..
Thanks
Old Oct 20, 2014 | 01:18 AM
Fast_Freddie's Avatar
Veteran: Navy
Uh, you never mentioned which injectors you have or if you are going to be running pump gas or E85...
Old Oct 20, 2014 | 04:44 AM
Seidelly's Avatar
Sorry...
I will probably be running 93 for now..
I have fic 1650's
Old Oct 20, 2014 | 08:50 AM
Cupkake.Luver's Avatar
My 255 cut me out at a little over 500HP. I think you should upgrade to be safe but thats just my opinion. Not an expensive mod. I got a 450 and its much better but I'm also at more HP.
Old Oct 20, 2014 | 08:57 AM
kaj's Avatar
kaj
from my experience 500whp, with a bit of luck, is where a Walbro 255 starts to tap out. that's with everything else being stock. my 255 was unmodded. you have plenty of injector, so that's not a concern.
if i were going for that number on a regular/daily driver basis, i'd feel more comfortable doing a double pumper.
Old Oct 21, 2014 | 02:06 AM
Veteran: Navy
Are those the new FIC 1650s or are these the older low impedance injectors? If they are the older ones, that is what you are going to have the most issues with... especially at a low pulse width and trying to get them to play nice with pump gas...
Evokid03
Oct 29, 2010 02:00 PM
barflea101
36
Nov 15, 2006 03:12 AM
GgreyEVOIX
15
Feb 21, 2006 03:45 PM
GREDDY
10
Oct 3, 2004 12:25 AM
gt40
Mar 15, 2004 08:03 PM
