Downpipe question
Old Mar 15, 2004 | 06:08 AM
boomn29's Avatar
Originally posted by Evo Ate
I'm a big advocate of not going with the 3" downpipe if you plan on sticking with the factory turbo, you will miss the torque. I went with the HKS, which is around 2.6-2.7". It has worked great for me. Most JDM builders using the 16G turbos are using the slightly smaller downpipes for a reason....my two cents.
Does the HKS bolt to the stock cat then? And miss the lower ties bars for an easy install??
I have already added a UR 2.5" cat-back so looking for a downpipe to finish it off. Thanks.
Old Mar 15, 2004 | 06:11 AM
boomn29's Avatar
Re: Downpipe question
Originally posted by Moki97
Well, for now my budget is $1600.00 (wife's orders). This is what I am planning to get:
- Espelir JGT500R Cat Back Exhaust
- HKS 2.75 downpipe
- XFlash Re-mapped ECU or Works P2
How much HP/Torque do you think I should get with that...
These things are hard to guess-timate. I'd guess close to 50whp.
Old Mar 15, 2004 | 05:24 PM
boomn29's Avatar
New question:
Would adding a downpipe decrease my fuel economy? $2 a gallon is getting pretty steap!
Old Mar 15, 2004 | 09:24 PM
SoR's Avatar
SoR
By the way... HKS downpipe is 65mm or 2.55".
Not 2.65" not 2.75" --> 2.55"
Most vendors have posted incorrect info. HKS website says it's 65mm and if you do a search, for the same reason one member has messured the DP and it turned out just like HKS has it on their website -> 65mm.
Old Mar 16, 2004 | 02:03 AM
RonV's Avatar
Yeah, I checked the website. IT SAYS 75mm!
Old Mar 16, 2004 | 09:37 AM
boomn29's Avatar
New question:
Anybody on this question?
Old Mar 16, 2004 | 02:59 PM
David Buschur's Avatar
Get the 3" downpipe. Our EVO on the stock turbo made 390 whp and 390 ft lbs of torque. Not torque missing in our car and it ran 11.65 at 117.88 mph.
The only way I wouldn't suggest getting a 3" downpipe is if you aren't going with 3" after the downpipe.
David Buschur
www.buschurracing.com
Old Mar 16, 2004 | 03:10 PM
boomn29's Avatar
David Buschur
What about those of us already with after-market 2.5" cat-back exhaust???
Old Mar 16, 2004 | 03:12 PM
mikesevo8's Avatar
Then they lie....
I have to second SoR on this. When I received my HKS DP last week, my dad measured it with calipers.
It's 2.55" (OD) from end to end. It's 2.45" ID.
It's still here in the box. I'll go measure it 3 more times, but I don't think it's gonna grow...
As I said in another thread, if you don't care about it being polished, might as well get
the Buschur 2.5" and save some cash.
Old Mar 16, 2004 | 03:14 PM
boomn29's Avatar
I found the 2.5" Buschur downpipe pretty cheap on a site the other day. I think $225.
As long as it clears everything w/o removing tie bars, that sounds like a pretty good choice then.
Old Mar 16, 2004 | 04:15 PM
NOVA EVO's Avatar
David Buschur
I'm going with 3" all the way back when I get my exhaust done...
Old Mar 16, 2004 | 10:46 PM
SoR's Avatar
SoR
Not sure which website you were checking but here:
http://www.hksusa.com/products/?id=661
says:
Part No.: 3306-SM002
Application: MITSUBISHI Lancer Evolution 2003
Piping Dia. (mm): 65
Price: $445.00
Bananayellowevo
Nov 25, 2016 09:12 PM
TxFAkuma
Jul 8, 2016 08:10 AM
XxLaNcErGTSxX
10
Aug 10, 2009 02:57 AM
nala
Feb 1, 2009 08:05 AM
kmcknight
Oct 26, 2006 06:36 PM
