uhm......are my pistons in backwards?
Old Nov 4, 2014 | 07:52 PM
robbyredneck's Avatar
after a catastrophic timing event i went to put my head on and noticed that the dots are toward the trans. is this the way or no? i have built tons of engines and the dots usually go to the crank snout. heres a pic.
Attached Thumbnails uhm......are my pistons in backwards?-wp_20141104_003-2-.jpg
Old Nov 4, 2014 | 07:55 PM
batty200's Avatar
The larger valve reliefs should be on the intake side.
Old Nov 4, 2014 | 08:00 PM
it's not
Old Nov 4, 2014 | 08:01 PM
could this be a case of an engine swap?
Old Nov 4, 2014 | 08:03 PM
reactionevo8's Avatar
yes,they are backwards
Old Nov 4, 2014 | 08:06 PM
thanks. they'll stay right there.
Old Nov 4, 2014 | 08:35 PM
Sharkbite2000's Avatar
If your asking that question , I think you shouldn't mess with that get someone who does
Old Nov 4, 2014 | 09:42 PM
94AWDcoupe's Avatar
many early 4g63 engines running evo8 pistons with the cutouts backwards. not a big deal at all as far as cutouts are concerned. . but it is a big deal for evo8 to run them backwards. the wrist pin is offset backwards now. you should pull the pan and flip them.
Old Nov 4, 2014 | 11:20 PM
Fast_Freddie's Avatar
Veteran: Navy
I am sure the reason he is saying they wills tay right there, so so teh shop that put the engine together can fix it and possibly the head damage as well...
Old Nov 5, 2014 | 05:00 AM
i guess sarcasm doesnt type so well, i apologize. i have screwed lots of engines together.
can you elaborate. this was the kind of info i was fishing for.
bought the car used from tx. and am uncovering lots of naughtiness. i will be fixing everything so i know whats in it.
thanks to all you guys
Old Nov 5, 2014 | 06:56 AM
todd6027's Avatar
reasoning is to keep the big end bearing tangs on the correct side
Old Nov 5, 2014 | 08:08 AM
<p>so the rods are directional?</p>more so can the rod be right and the piston wrong?
Old Nov 5, 2014 | 09:06 AM
94AWDcoupe's Avatar
the piston pin is not centered. it is offset to one side. this is done so piston doesnt rock at top dead center. results in a quieter running engine. with the piston installed backwards there would be noise being created since the offset is in the wrong direction. piston would rock more than pistons that dont have an offset. rods are not directional. they can be installed either way.
Old Nov 5, 2014 | 10:18 AM
so whats the down side other that thrust load and noise? frankly i thought these cars were kinda like snowmobiles. they vibrate. are noisy and you smell like exhaust when your done riding them. can i just leave it. or is that considered gross incompetents? ran fine before the tensioner let go.
Old Nov 5, 2014 | 04:32 PM
ok done being lazy i pulled them and flipped them. on to the next oil leak. thanks for the help guys.
