How much torque can the 6-speed Transmission handle
Anyone have any input on how much power/tq the six-speed transmission can handle before things start to break... Currently running 510whp/400ishTQ and the tranny seems fine.34k miles... Running a carbonetics twin disc as well.
I want to make a little more power/TQ; and reliably be able to track (road course) the car without much issue.
Note: haven't launched the car since I've had it.
I have read 450 tq is about as much as u should push them stock. The main thing that I have read is that they fail from overheating. And that first gear is actually stronger than the 5 speed so launching isn't what breaks them. It is if you do a lot of track days and get it hot 4th gear goes out. That's just what I've read. If you plan on tracking it I'd suggest a transmission cooler
I recently had a fair bit of work done to my IX so was looking into this, and I read you shouldn't go much over 400tq, 380 if you want to be safe, so if you're already at 400 I wouldn't go much higher unless you can afford to replace the trans if it goes
I was always told 400lbs when I had it in my car. I've since swapped to a UR 5spd, but if you install a trans cooler that should help A LOT. The issue is the 4th gear. From what I remember the 1st-3rd gear is the same thickness as the 5spd, but 4-6 are thinner to get them to fit into the same size case.
it all depends on how its driven. my guess is that it can handle max 450 ft-lbs when driven smoothly and keeping temps under control. 400 is probably more reasonable for true longevity for street driving. abusive shifts and/or hdpe will probably kill it at 300 ft-lbs.
