Strange Whirring Noise After I/C install
Originally Posted by TURBODAWG
To answer your question about hooking up the wastegate lines. The simplest way to tell you is this. Do you know the stock intercooler pipe that was bolted to the turbo? It had a small nipple on it that hooked to the actuator and the solenoid and was T-ed and so forth. You no longer have a pressure source on that intercooler pipe with the new greddy pipe, therefore, you T into the BOV pressure/vac line and hook it into the vac line that was previously connected to that little nipple. In this scenario you are using the intake manifold pressure instead of the intercooler pipe pressure. I hope that makes since.
Brian
Brian
I did find some cheapo $5 40 pc tool sets at walmart which had uber small 1/4" drive 12mm sockets. I was able to tighten the bolts a little with my torque wrench, but not before I destroyed the socket (damn cheap sockets!) I thought I had it down pretty tight, but upon acceleration it's still whistling and stumbling like a ****. Is there a recommended torque for that particular IC pipe?
Originally Posted by zstryder
Thanks, that's what I did, just wanted to double check.
Brian
Man... as it turns out, I destroyed 1/2 of the thread on the hard to reach bolt (not the bolt thread, but the thread on the turbo). I tightened the thing at an angle due to the slack, as you mentioned... this is out of my hands now. I have no clue what to do. I'm gonna drive the car to a shop tomorrow and see what they can do... thanks for the help, but I think I'm at a dead end now.
Zstryder: Sorry man, that sucks. You are left with a few choices now. You can either drill and tap a larger SAE thread into the turbo outlet flange, or drill it and insert a helicoil that matches the stock metric thread. Either one will probably need to be taken to a machine shop to have done.
If you are really lucky, you maybe able to get a slightly longer bolt, this will allow it to get into the hole far enough to get to the threads that are still good.
I think Hooptie157 had the same problem when he installed his, try PM'ing him and ask how he got his fixed.
Brian
Brian
I took it to an auto shop today and they said they couldn't retap the thread, so they used a stud...? Anyway, they test drove and said there's a boost leak somewhere cause you can hear it. So I went home, took off my bumper, retightened all the couplings, checked all my IC hoses, and all the vacuum hoses too. Everything seems tight. I test drove, and still, I'm only getting 15 psi max and you can still hear the leak. I think that IC pipe is still suspect, and the shop wasn't able to get a clean seal. Perhaps I should ask them to use silicone sealant or something?
Sounds like you still have a boost leak. OR another idea.
Is your original OEM boost controll lines still being used? (except you are getting pressure source from BOV). The OEM boost control lines have a restrictor in them that will cause the boost to run higher. If you replace any of the original lines, then the boost will be lower. I already had to troubleshoot another Evo owners low boost problem after the intercooler install. He replaced the OEM boost control lines when he hooked up to the BOV line and that caused his boost to be about 13 or 14 psi.
Brian
Brian
WOW this sounds like the same thing that happened to me!!! I had to rethread the turbo bolt hole because I stripped the crap out of it. Just get a good taper, tap it and you should be good to go (the metal isn't that strong so taping shouldn't be a problem).
Brian
Brian
Hmm... they just called me back and said after retesting the whole system, they could *not* find a leak. They said that the sound I'm hearing is probably the air resonating inside the IC pipes (similar to how getting an intake pipe will really amplify that *sucking* noise).
They also mentioned to me that I forgot to install the restrictor, so they said to try that when I got home from work and see how the car pulls. If the car doesn't pull like it should, then they suggest I send my ECU back to Visnhu for a reflash... hmm, at least it's not a leak in the IC, like I thought it might have.. that's good to know. On the bad side, they said they jerry rigged the hose with a makeshift restrictor to see how the car would pull on the dyno, and they were only able to get 238whp??
This sucks..
PS. they also said to put the restrictor in the wastegate line, and not the BOV pressure line... which one should it go in?
This sucks..
bump... got a question.
If my boost gauge is reading standard boost (21-22psi, tapering down to 19psi) then is it still possible to have a boost leak? Maybe this whirring sound I'm hearing isn't a leak, after all?
nOISE
You should get some allen head bolts instead of the cheap hard to use Greddy bolts. I had the same problem with mine and it was because I couldn't tighten the pipe that connects to the turbo. Took it to the local rally car shop and they used the allen headed bolts. Much easier!
Same problems! I went with the Buschur Deluxe FMIC. I am still getting a whistle/whine under boost. What about a larger gasket? Or using some kind of gasket sealent?? will that fix the noise.
