well, time for a fluid change...still a little confused
Old Mar 17, 2004 | 10:21 AM
NYEVO8's Avatar
Originally posted by 93civEJ1
the transfer case is one of the diffs, its the center diff, use redline 75w90 straight outta the bottle for both center and rear diffs i have read.
so the front is just an open diff, or some s@#$ like that.
ok i think i got i now
tranny= penzoil synchromesh (straight out of bottle)
diffs= redline 75 w 90 (straight out of bottle)
no friction modifier additives needed for this,right.
Old Mar 17, 2004 | 10:39 AM
EvolvedDSM's Avatar
Actually, the transfer case houses the front diff. The center diff is incorporated inside the tranny.
From
Manual transaxle Gear oil API classification GL-4
SAE 75W-85W or 75W-90
Transfer oil Hypoid gear oil API classification
GL-5 SAE90
Rear differential gear oil Hypoid gear oil API classification
GL-5 or higher
• Above −23°C(−10°F): SAE90,
85W-90, 80W-90
• −34 to −23°C(−30 to −10°F):
SAE80W, 80W-90
• Below −34°C(−30°F): SAE75W
It's not uncommon to go with 75W-90 in all three. GL-4 tends to be kinder to the synchros while GL-5 is supposedly better for the bearings. So, another route would be 75W-90 GL-4 in the tranny/center diff and an 80W-90 GL-5 in the transfer case/front diff and the rear diff. I know some synthetic manufacturers incorporate a friction modifier for the LSD in their fluids--you may need to add some for the rear if this is not the case. Otherwise, it's straight out of the bottle.
Old Mar 17, 2004 | 10:44 AM
93civEJ1's Avatar
yup i think you have it.
Old Mar 24, 2004 | 09:27 AM
OX's Avatar
OX
Who makes a straight 90W or even a an 80W-90 weight GL-5 synthetic?
Old Mar 24, 2004 | 09:43 AM
93civEJ1's Avatar
couldnt tell you but i finally got all my crap changed out, accidentaly got caught up in a rainstorm while doing my rear diff, it was a pain and a mess...did it laying in the driveway under my car with me getting soaking wet But i have it all changed out finally...Pennzoil Synchromesh in the tranny, Redline 75w90 in the diffs.
Old Mar 24, 2004 | 11:58 AM
OX's Avatar
OX
My owners manual says SAE 90W. Don't think I've ever seen that for sale.
Old Mar 24, 2004 | 01:43 PM
93civEJ1's Avatar
Old Mar 25, 2004 | 07:19 PM
Ferb's Avatar
Due to the inherent low-temperature flow of synthetic lubes, 80w-90 is just too small of a spread. In essence, synthetic base stocks are "too good" to be rated like that. Most are going to be 75w-90 or 80w-140.
When choosing an aftermarket synthetic lubricant, one has to second guess what the manufacturer REALLY wanted. With most factory fills being conventional lubes, stepping up to synthetic generally results in better low temperature characteristics with no loss of high temperature viscosity.
That help?
ferb!
Old Mar 26, 2004 | 05:41 AM
OX's Avatar
OX
Guess I'm a little gun shy after all the strories back from DSM land about MTL (admitantly lighter than 75W90, but you get the point). I understand the multiweight rating, but why would mitsu call for a SAE90 straight. Are even they a little paranoid about too light a TC oil, especially since I don't even thnk I drained out the supposed .58 quarts that it supposedly holds.
Old Apr 14, 2004 | 08:22 PM
92Tsi's Avatar
I bought the rear diff oil right from Mitsu. It says it is SAE 90. It is the exact replacement per the owners manuel 8149630 EX. My question is can this be used in the transfer case as well? If not does anyone have th part number from Mitsu for the transfer case oil?
Old Apr 14, 2004 | 08:45 PM
raced_EvoVIII's Avatar
I went with all redline fluids and i could not be any happier, the car shifts as smooths as butter and the t case wine is much less noticeable.
Old Apr 14, 2004 | 09:13 PM
Satori's Avatar
With the tranny and rear diff you have some leeway. For the transfer case don’t use anything other than what the manual states! There are way too many people around here with busted transfer cases. SAE 90 only.
Old Apr 16, 2004 | 09:16 AM
Ultor's Avatar
I did MT-90 in the tranny, and Redline 75w-90 in the T-case and rear diff.
Then I read this =P http://buschurforums.com/forum/viewtopic.php?t=2500
Looks like I'll be making a trip to Mitsu tomorrow =/
Old Apr 16, 2004 | 09:27 AM
Cordwood's Avatar
Yeah, I've heard mixed reviews about Redline. I'd take it out and go with stock juice.
Old Apr 16, 2004 | 09:32 AM
93civEJ1's Avatar
ah hell, you mean i have wasted all that time and money?? now what do we need to get?? this is BS..lol
