Car Revs up after pushing clutch pedal in
So my build finally has come to an end ( For now.. ) and I finally got the tune cleaned up yesterday and drove around doing a full pulls here and there, and I noticed something weird..
If I put the clutch in to shift at 6500~ Rpm the car will rev up 500RPM before the RPM's drop again..?
Has anyone had this issue before.
Im thinking it might be the clutch position sensor?
Its an exedy triple disk.
This will likely sound stupid but are you sure you're fully getting off the throttle before you start clutching it? Try slowing down your shifting to make the pedal work very deliberate to see if it still does it.
If it does, maybe make sure the throttle isn't sticking, be it the plate itself or the pedal getting stuck on the floormat for half a second for example.
I am almost certain that I had played with a "decel fuel cutoff" calibration in the tephra sw that delayed the fuel cut based on rpm and load. If you have access to your sw, can you look up those values?
TurboTylerIX
21
Dec 19, 2017 11:16 AM
hameedosh
Jul 22, 2009 03:41 AM
Gruppe-S
10
May 7, 2007 04:56 PM
