What EVO engine fit in my 06 Outlander Turbo
Old Nov 26, 2014 | 05:22 AM
svaleng's Avatar
What EVO engine fit in my 06 Mitsubishi Outlander Turbo, VIN: JMBXNCU2W5U002167, 4G63-7-A1, part 1000A183?
Old Nov 26, 2014 | 11:50 AM
ColtiXim's Avatar
Welcome.
Evo 7 to 8 long block will fit directly.
You need to keep the Outlander electrical throttle body and TD04 turbo + injectors with the original ECU management .
What is bad with your actual motor ?
Old Nov 27, 2014 | 06:09 AM
svaleng's Avatar
What EVO engine fit in my 06 Outlander Turbo"
Originally Posted by ColtiXim
Welcome.
Hello ColtiXim. Thanks for answering my question.
There are many verson of 4G63-7- (J1 to J9, Z1 to Z4 and so on) Part No. 1000A480 to 83. These engines sitting in Lancer "CT9A" from 2000 to 2007
Do you know if there are major changes in these engines, or whether all fit in the car. It is perhaps difference whether it is a 5M / T or 6M / T transmission?
I just bought the car. Discovered after some time that there is a weak viberasjon and noise from the engine. Disobedience was strongest from the catalyst, so that it was replaced first. Eventually I discovered that the car has just changed the clutch and flywheel, for a smaller flywheel casualty.
It is difficult to explain noise, but the sound has been swinging, and the frequency of the sound, increasing in frequency when speed of the motor increases. At 5000 rpm, then comes a higher noise like. This sound sounds as if it is loose cover or heat shield about is resolved.
I'm afraid there may be something wrong with outbound shaft to the flywheel that is defective. Therefore examines the ability to import me a new engine.
Side-Swipe
Outlander Sport
Mar 22, 2023 08:21 AM
LeoFama617
Outlander Sport
Mar 1, 2016 08:22 AM
LeoFama617
Outlander Sport
21
Jun 2, 2014 02:35 PM
catherineapop
Outlander Sport
16
Jan 23, 2013 06:52 AM
Exyia
Apr 13, 2011 06:00 AM
