Pennzoil Synchromesh.....anyone?
Old Mar 15, 2004 | 06:33 PM
93civEJ1's Avatar
why will it just be fine until the next fluid change??? should we not run the GM or Pennzoil or BG for that matter from now on??
silverE8's Avatar
i've switched over at 3000 mi., only thing i noticed is when it is cold you have to take it easy until the trannyfluid gets warmed up. other than that no problems at 8500 mi.
Old Mar 15, 2004 | 06:35 PM
93civEJ1's Avatar
and you are running the Pennzoil or the GM??
Old Mar 15, 2004 | 06:41 PM
93civEJ1's Avatar
also....1 more question is the GM and Pennzoil synchromesh's a GL-4 fluid like we are supposed to use??? i couldnt find that anywhere.
Old Mar 15, 2004 | 06:53 PM
93civEJ1's Avatar
one more thing again.....for anyone wondering if GM and Pennzoil synchromesh are equivalent, then look at number 3 in this link :
http://www.pennzoil-quakerstate.com/...l/pdf/g14c.pdf
Old Mar 15, 2004 | 07:21 PM
MrBonus's Avatar
Originally posted by Zeus
Been running the GM since about 3k in the EVO... 2nd gear grind went away after its use. I'm at over 18.7k now.
Have you had any problems with your drivetrain otherwise? Transfer case or diffs?
Oh, and is there a specific weight to get with GM Synchromesh or is it all the same? Is it safe to use in the diffs as well as the tranny?
Great thread, guys.
Old Mar 15, 2004 | 07:30 PM
93civEJ1's Avatar
no there is no weight it's specifically just GM synchromesh or Pennzoil Synchromesh(autozone). I would only use it in the tranny though, I have heard great things about synchromesh and bought those 3 qt's tonight from autozone.
Old Mar 15, 2004 | 07:31 PM
MrBonus's Avatar
Yeah, I just read your other thread.
I think I'll go with Redline in the diffs. Thanks.
Old Mar 15, 2004 | 07:34 PM
93civEJ1's Avatar
hehe exactly what im doing ...Synchromesh in the tranny and Redline 75w90 in the diffs. cant wait to get this stuff in...all the hype i have been reading about the Pennzoil and GM synchromesh(both the same) are making me anxious.
Old Mar 15, 2004 | 07:37 PM
silverE8's Avatar
i talked to jon at tre,he said the gm was just fine, in my transfer case i use redline shockproof gear oil. no problems so far, just make sure when you change your fluids, to fill them until they overflow to ensure that they are full.
Old Mar 15, 2004 | 07:39 PM
Darkstar1's Avatar
Check out this page:
http://www.pzlqs.com/Tech/Pdsheet/Do...omeshFluid.PDF
It says that Pennzoil Synchromesh is compatible with brass synchronizers, which is why the Evo needs GL-4 fluid.
Old Mar 15, 2004 | 07:40 PM
93civEJ1's Avatar
what is TRE, and sweet, GM/pennzoil is fine...good to hear.
Old Mar 15, 2004 | 07:41 PM
93civEJ1's Avatar
yeah i read that Dark...i knew that supposively the GM and Pennzoil are "yellow metal" friendly.
Old Mar 15, 2004 | 07:43 PM
MrBonus's Avatar
What is the stock stuff Mitsu uses in the diffs?
The Synchromesh sounds like it's money though.
Old Mar 15, 2004 | 07:45 PM
MrBonus's Avatar
0.58 quarts of Hypoid gear oil API classification GL-5 SAE90
0.58 quarts of Hypoid gear oil Mitsubishi Genuine Gear Oil Part No. 8149630EX or equivalent
Hmmm... I might stick with the factory stuff. I haven't had any issues with my diffs/transfer case. (*Knocks on wood)
