Reuse Headgasket When Doing Headbolts
Old Mar 15, 2004 | 08:24 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
As topic says....i am doing hks cams and arp headbolts ....and was just making sure that people are reusing the stock headgasket ....just pulling all the stock headbolts and then never taking off the head just installing the new bolts and tightening them to factory specs? Anything i should know or tell the shop when installing....?
Old Mar 15, 2004 | 08:31 PM
mikesevo8's Avatar
That's what I'm doing.
Someone already posted about doing this. Just do one bolt at a time.
Use the torque pattern as a guide for the replacing order.
Take one out, put the stud in, tighten, put on the washer and nut, torque to spec.
Make sure the engine is cold.
I can't think of a reason why it won't work out.
Old Mar 16, 2004 | 07:41 AM
superz's Avatar
don't pull the head off, just swap bolts. Its totally safe to do this. Only loosen one bolt at a time. Make sure you have an accurate torque wrench!
Old Mar 16, 2004 | 08:01 AM
turboDan's Avatar
Yes,what superz said^^^^^^^^^^^^^^^^^^^
never,never reuse a head gasket once all torque/load is removed
from head.By doing it one at a time this does not happen,BTW,
no need to remove cams to install head studs,although I see you are replacing cams anyhow
stefenboy
Dec 9, 2015 03:20 PM
Dragracer187
Feb 15, 2009 12:14 PM
RyuEvoIX
23
Nov 8, 2007 07:18 AM
trboboost91
17
Oct 28, 2007 09:10 AM
Illrunya
17
Aug 31, 2005 07:10 PM
