E85 Base Tuning 1200PTE AEM
Old Dec 16, 2014 | 12:38 PM
Rowland2004's Avatar
I am looking to setup my AEM on a base tune for E85 so i can get it tuned. Right now i am setup on 93 and my A/F is around 11.2 at max boost (28psi). I am tuning with AEM V1 and just looking to see if i should add 30% across the board or what i need to change in the starting table to. I am just looking to do a conservative tune as i made 456 on a mustang dyno.
Any help would be great!!
I have the following setup:
05 Evo
BR Stage 3 motor (top/bottom)
BR 272
FP3586
BR Double pumper
PTE 1200cc
BR 3in TBE
Exedy Triple
Buschwacker trans
AEM V1
Old Dec 18, 2014 | 04:23 PM
Aby@MIL.SPEC's Avatar
Adding 28-30% would be a good start for simple fueling.
However your afr targets for various loads & engine speed should be altered, as well as timing, not only for peak power, but to generate better spool-up as well.
Old Dec 22, 2014 | 05:22 PM
Beemen550's Avatar
I have a couple v1 maps from my, 2.3 e85 pte1600 aem v1 s362, if you want to compare
Rowland2004
AEM EMS
Dec 22, 2014 05:35 PM
GsrJake
Evo X Dyno Results
25
Mar 17, 2013 03:16 AM
InjectedPerformance
84
Jun 29, 2009 12:33 PM
ARVSHOP
Aug 26, 2004 01:08 PM
