PST CF 1pc drive shaft installed - 700hp/510tq
Old Jan 5, 2015 | 11:45 PM
TheBoz's Avatar
Originally Posted by chamelieon
Any way to add this CF drive shaft without cutting part of the chassis like possibly lowering the rear diff a bit to clear better?
The clearance issues is closer to transfer case. So you would need to lower whole engine. For me I am pretty sure that lowering the rear diff was not needed, but that might have given me a little extra clearance.
I have about 100 miles on the car now, and I really enjoy the new drive shaft. It makes driving on a 8 leg QM Twin much smoother. So the car is a lot more fun to drive now. I am going to try to hit Streets of Willow or Big Willow during Jan, and I will hit the drag strip in Feb.
Old Jan 24, 2015 | 01:42 AM
ryukinevo's Avatar
Question
Great Review to both you and evodan2004 . This is probably an obvious question, but is it an investment in your car.
How easy would it be to reweld the mounts for the stock drive shaft in case you wanted to return it back to stock?
Thanks!
Old Jan 24, 2015 | 10:40 AM
TheBoz's Avatar
For me there is not a plan to go back. I was full commit on this project.
If you remove the spot welds then you could reweld the hangers back is pretty easy. The is so much slop in the oem shaft that it does not need to be in there dead nuts. So easy to revert if you can weld.
Old Jan 24, 2015 | 10:44 AM
TheBoz's Avatar
As for the investment question these cars are BOATs(break out another thousand). So if you think there is any roi you are crazy.
I have about 500miles on the shaft now and I am super happy with it.
Old Jan 24, 2015 | 12:47 PM
Nimpoc's Avatar
Thanks for the review! Was there any reduction in drivetrain lash? Specifically at 3k+ tipping in and out of neutral throttle did the driveshaft reduce 'slop' in the drivetrain?
Gotta agree with 03whtgsr that you cut out some good stuff from the tunnel. Might want to consider making a tunnel brace which could also act as a driveshaft hoop (not that CF shafts really need them - BANG!).
Old Jan 24, 2015 | 01:03 PM
EvoDan2004's Avatar
I ditched the entire tunnel bracket. I have not noticed any issue. I do however have a cage.
Old Jan 24, 2015 | 01:40 PM
marck_c's Avatar
What's the approximate length of that shaft?
Old Jan 24, 2015 | 02:44 PM
mitsubeastlee's Avatar
Does the driveshaft bottom out in the transfer case? I installed the AWDspec 2 piece DS and it doesnt bottom out in the transfer case, I have also noticed a spinning metallic sound that is always present if the cars rolling even when not in gear. I m curious as to if this is normal with a NON OEM driveshaft?
Old Jan 25, 2015 | 10:22 AM
AreSTG's Avatar
let us know what top speed you hit with that thing. It's so looong, I am really curious about the 180+ mph range...
Old Jan 25, 2015 | 03:06 PM
TheBoz's Avatar
It should not bottom out. It needs the slack for the engine movement. Next time the car is in the air I will take a pic.
Old Jan 25, 2015 | 03:11 PM
TheBoz's Avatar
April is the next time California speed way is open, but I am guessing that I will top out about 155-160mph. My ***** are not 180+mph big yet. Also no cage in the car, or roll bar.
Old Jan 26, 2015 | 04:32 PM
Thank you, yeah I have driven about 25 miles on her, besides the ever so slightly "ting ting ting ting" while moving which could just be extra driveshaft sound im not used to, it seems fine. Its not leaking so I know the DS is seated enough, I just thought maybe it was modified slightly too short but I guess that normal play.
Im also gonna take a look under the car to see if the DS is hitting anything.
Old Jan 26, 2015 | 07:38 PM
jacked cobra's Avatar
At what power level is this needed?
Old Jan 27, 2015 | 12:42 AM
EvoDan2004's Avatar
Right around 272hp
Old Jan 27, 2015 | 11:24 AM
TheBoz's Avatar
Originally Posted by evodan2004
Right around 272hp
I found 273hp to be the sweet spot.
This is a mod you could do at any HP level. It is never required, it is just one of those things you do because you want to make the car smoother. I have been running the car in daily mode driving is LA traffic the last few weeks here and everything has been going really smooth. I have noticed a small leak from my transfercase, at the output seal. So I am going to replace it and see what happens. Time to do fluids again anyhow.
