Boost gauge reading
Old Jan 21, 2015 | 03:58 AM
araz5260's Avatar
Boost gauge reading
Hello everybody. I want to ask about reading boost gauge. At idle, it shows around -17 psi and at boost, it goes up to 8 psi. Does it mean boost is working at 25 psi? Or the 8 psi should be read around 25 psi? If anyone knows, please help about it.
Old Jan 21, 2015 | 04:38 AM
egis's Avatar
-17 at idle is your vacuum.boost starts from 0 and up. If you hitting 8 psi you have some serious boost leak or something else.
Old Jan 21, 2015 | 05:03 AM
araz5260's Avatar
I think there is not boost leak because i would hear the sound if there is, turbo is working fine. Fuel pressure is around 40 psi and it is also normal. What else can be the problem?
Old Jan 21, 2015 | 10:31 AM
egis's Avatar
You can't diagnose/hear boost leak while driving.you have to do boost leak test.so your max boost is 8 psi ?
Old Jan 21, 2015 | 11:39 AM
araz5260's Avatar
Yes but it seems like it is working quite well. Can it be gauge problem? and today i checked the injectors and one of them is not working. They cleaned the injector but it did not work. So i must buy an injector. It is surely related with boost but can it cause that much boost difference?
Old Jan 21, 2015 | 11:56 AM
Ev0ikon's Avatar
A lot of people can't seem to get this point.
Old Jan 21, 2015 | 11:59 AM
Ev0ikon's Avatar
So. You call it "well" with one cylinder missing?
Old Jan 21, 2015 | 12:14 PM
araz5260's Avatar
It is pumping but not as much as others.
Old Jan 21, 2015 | 12:46 PM
Ev0ikon's Avatar
If there is no fuel then there is nothing to pump that piston.
Old Jan 21, 2015 | 12:54 PM
egis's Avatar
Stock boost is 19psi you hitting just 8psi yet one of your injectors said good buy.fix injector first deal with boost later.you can ruin your engine.that would be my advice.
Old Jan 22, 2015 | 07:52 AM
araz5260's Avatar
can it be related with injector? i mean can injector affect that much boost difference?
Old Jan 22, 2015 | 08:14 AM
Viral Racing's Avatar
The turbo is spun by the exhaust gasses created from burning the fuel in each cylinder. If one is not working you lose 25% (give or take) of that exhaust energy... so yea, and as they said fix the fuel first worry about boost after, do a proper boost leak test... Don't blow up your engine...
Old Jan 22, 2015 | 08:37 AM
araz5260's Avatar
Ok thank you man.
Old Dec 31, 2025 | 04:21 PM
Alberto0216's Avatar
Wanted to add something hear see if someone could relate
So Evo x here I bought this car this way but my boost gauge at idle reads 20ish and when I drive it drops to lower number is this how it should be?
I know I have a leak on the dp could this be the reason why? Any advice I would appreciate it.
Old Jan 2, 2026 | 07:28 AM
schuhie's Avatar
Please stop spamming 10 year old threads with your question. This forum is active but a bit slower for responses than facebook pages. People will respond, it just takes a day or 2 sometimes.
