Hydraulic release bearing for Competition Twin?
Old Jan 24, 2015 | 10:55 PM
BlackOperative's Avatar
Hello everyone. I am in the process of building a 2.4 stroker for my 2003 5-speed Evo 8, and have a question about the clutch. I got an excellent deal on a competition clutch twin disc, but was wondering if anyone knew if you could use a hydraulic release bearing, either from quartermaster or tilton. I realize I can use the included pull-push conversion, but like the idea of the HRB. I don't really care to buy one for what they cost and just try it out. And I will call QM if it comes to that, but not sure how helpful they will be considering I didn't buy a clutch from them. If anyone has experience in this it is greatly appreciated. The QM one comes with so many shims, one would assume you could make it work, but I'm not ready to just waste 300 dollars trying it out. Thanks everyone.
Old Jan 25, 2015 | 04:15 PM
SiriusEvo's Avatar
Veteran: Army
The Quartermaster Hyd. Release bearing works fine with the comp twin on my car. Go for it. You will need to buy bolts to mount it in trans. Doesn't come with those for some stupid reason
Old Jan 26, 2015 | 06:15 PM
SiriusEvo, I thank you for the confirmation sir. Made my life much less stressful, the last thing I need to worry about with this full build is parts that won't fit when tranny time comes. Did you have to shim it? Are you using a clutch pedal stop? Thanks for the reply again man, appreciate it.
Old Jan 26, 2015 | 07:36 PM
Stellybeats's Avatar
Sub'd
Old Feb 4, 2015 | 10:03 PM
SiriusEvo's Avatar
Veteran: Army
Clutch stop is highly recommended and you do not need any shims, well at least I did not.
Old Nov 21, 2015 | 06:03 PM
fastboat4life's Avatar
Did this end up working out for you too? Just wondering because I was wanting to do the same thing.
Old Mar 22, 2017 | 08:13 AM
brandonc452's Avatar
5 Year Member
Hy
did you ever get this resolved? I'm trying to do the shimming on my 2.4
deylag
16
Feb 18, 2017 10:25 PM
mberenis
May 17, 2014 05:51 PM
Anarchy99
65
Feb 14, 2013 07:35 AM
jonzie04
Sep 3, 2012 10:13 AM
Wickedwhite8
Dec 15, 2010 07:36 PM
