Best cams for stock valve springs
Old Feb 2, 2015 | 10:15 PM
mrm95's Avatar
Well do people commonly install valve springs with the head still on? Ive heard that for each cylinder the piston needs to be at TDC so valves dont fall in. Maybe ill do the FP red with stock cams. Ive seen good results there..
Old Feb 2, 2015 | 11:37 PM
asu11's Avatar
You can if you pressurize the cylinder you are working on. This will prevent the valve from dropping. There are a few other ways such as moving the piston to the top or the old nylon rope trick.
Old Feb 8, 2015 | 11:00 PM
ace33joe's Avatar
I am satisfied with my Tomei Poncam Type-R 270 with stock springs.
But when head is open, I will definitely upgrade the springs (or cams too).
GSC has stock replacement seats and mild springs (5039) that are compatible with stock retainers, so unless going to high rpm / boost with aggressive lift cams, these parts might be a good option.
BTW, I didn't see difference by using GSC zero-tick lifters in terms of valve train noise when low oil pressure, I recommend clean stock lifters with diesel fuel as service manual suggests and reuse them.
Old Feb 8, 2015 | 11:17 PM
Arrrrgh's Avatar
good read
Old Feb 12, 2015 | 06:54 AM
turbojoe's Avatar
Ive been running cosworth m2's in my 9 for a few years now, stock springs and I take it to 7800. They're coming out now for an upgrade and I will do kiggly beehives with the new s3 cams.
But yes u can do springs with the head still on the car, I've done it many times. I use my cylinder leak down tester and apply 100psi in the cylinder and change them out. Make sure u plug any holes leading to the block, those keepers can be squirmy at times. Goodluck!
Old Mar 7, 2015 | 12:51 AM
mrm95's Avatar
Thanks for the helpful info everyone. I plan to rev to 8000 with this turbo im getting.. Still Kelfords or Cosworth M2's? I worry that may be too aggressive of a cam with that high of rpm
Old Mar 7, 2015 | 02:23 AM
Valentino46's Avatar
Originally Posted by EvowagonIX
Hks 272. I have in mine. Stock valvetrain.. daily driven 119,000 and going. No issues. Great bottom end and mid.
How do you find the HKS 272s i am thinking of them myself?
RJones
Jul 22, 2013 11:09 PM
Saleentones
Aug 3, 2010 06:55 AM
Liqquid
Sep 9, 2009 11:28 AM
Gruppe-S
18
Oct 23, 2006 11:10 AM
