What downpipe mounts to the stock cat?
I would prefer not to change my stock cat out however I'd like to upgrade my stock downpipe to an aftermarket 3", stainless steel downpipe.
However I'm having a hard time finding a downpipe that attaches w/o any problems to the stock cat unless there are some major tweaking to the downpipe (i.e. hacking off flanges, cutting down the pipe, etc.)
Does anyone know of any 3" downpipes that will just mount up to a stock cat?
I think Vividracing and Lancershop has some downpipes that might but their description is not straight forward (i.e. "does not require changing any stock catalytic components".
Additional question as well, what's the reason for getting a high flow cat as opposed to a cat delete pipe? Both still fail e-check, is engine noise slightly less with a high flow?
i don't have a 3" one on my car but know a guy that does. it is a helix and mounts very nicely. he wrapped it with the exhaust wrap since it is so close to the oil pan. they also provide spacers for the tie bar to space it down a tad. my hks 2.6 works perfect. take the old one off and installed the new one in about 10 mins. no spacers or washers needed!!
good luck!
good luck!
I'm specifically looking for a 3" dp, so WORKS and HKS are out of the picture.
Are there any other brand names to have a 3" dp that mounts to the stock cat?
TurboXS is the best looking one thus far.
I'm very surprised there aren't more manufacturers doing this since there are a good number of street Evos that want to pass emissions and upgrade their exhaust systems at the same time.
Thanks for the responses.
turboxs all the way i have it on my car now great stuff
SoR - I don't think any downpipes fit the stock cat. Most downpipe are designed to fit their (company's) test pipe or high flow cat.
cdavy - I don't think RMR fits the stock cat. A friend of mine called RMR up and asked if the 3" downpipe fits and they said nay.
dyueno - so basically you're saying WORKS downpipe won't fit with the stock turbo, you need the upgrade? Well, it's still only a 70mm pipe.
