Shifter Cables or Clutch Fork?
Old Feb 21, 2015 | 10:32 AM
Malfury's Avatar
I just want to identify the problem so I can know what I need to fix, so here's my story:
>One day, my clutch starts slipping.
>No problem, I'll fix it when I can get all the parts.
>Buy parts (Comp Stage 2 clutch kit + OEM TOB and OEM trans fluid)
>One day driving home, car stalls for no reason when I park at home.
>Starts the car and it fires right up.
>Next time I go out, the car won't engage any gear.
>Turn car off, throw it in reverse, start car and it bites.
>Drive the car around and it shifts without issue.
>Drive the car to work the next day, no issue.
>Drive the car back home and suddenly all gears are gone on the road.
>Pull over
>The car has the same issue as before, so I try the same trick as before..
>Only 2nd works.
>Drives to 2nd all the way home.
(Sorry don't know how to embed)
If you can see, the shifter won't stay in gears 1,2,5,6 or reverse. And clues on where I can start? Thanks in advance.
Old Feb 21, 2015 | 11:25 AM
evo8426's Avatar
Check the shifter cables on top of the transmission, look at the clips and make sure they are on all the way.
bostonhatcher
Jan 4, 2015 01:22 PM
MREvOTard
Aug 13, 2008 10:24 AM
Steve@NoLimitmotors
Feb 4, 2007 05:05 PM
MSTR MR9
Oct 27, 2006 12:04 PM
