HELP!!! Vaccum went from -20 to -13
Old Feb 28, 2015 | 04:11 PM
FreshEvoEight's Avatar
hey guys, ive owned my evo 8 for almost two years now and when i first got the car it was running in the neighborhood of -20 vacuum at idle. then a couple months ago kinda out of the blue it dropped down to around -14 to -13 vacuum at idle. i just went through my entire intercooler piping sytem, replaced all clamps i could find, did a boost leek test for good measure, and replace a couple of old looking vacuum lines. i cant find where i would have a vacuum leak and i was wondering if anyone would know of any suggestions of where to look next. thanks alot guys!
Old Feb 28, 2015 | 08:49 PM
Evo9_Dubai's Avatar
Did you install cams recently?
Old Feb 28, 2015 | 11:46 PM
nope, no modifications or changes were done.
Old Mar 1, 2015 | 05:35 AM
evo8426's Avatar
Have you checked the lines running to the EGR?
Old Mar 1, 2015 | 09:57 PM
those were the first lines i checked and they were all in good shape and where they belong
Old Mar 1, 2015 | 10:01 PM
lonestarr20's Avatar
Is your A/C ON when this happens
Old Mar 1, 2015 | 10:07 PM
no its showing the same regardless of the ac... Its gotta be a vacuum hose hiddin somewhere thats leaking...
Old Mar 1, 2015 | 11:03 PM
asu11's Avatar
boost leak check the car
Old Mar 2, 2015 | 08:22 AM
i already have (twice) as i said in my original statement
Old Mar 2, 2015 | 08:43 AM
Ev0ikon's Avatar
Do you know what cams you have? And what RPM does the car idle at?
Old Mar 2, 2015 | 08:52 AM
stock cams. and i think it idles right at 1k ill edit if im wrong once i go double check
Old Mar 2, 2015 | 05:14 PM
hutch959's Avatar
compression test
if compression is low, vacuum will be low... sometimes
Old Mar 2, 2015 | 06:53 PM
crritter's Avatar
I had this happen to my Evo. It just started to idle low and the vacuum dropped to -14 from -20. The car also sounded like it had a cam when my car is stock. My air fuel ratio stayed at 14.7 - 15.1 while this was happening. I fixed it by disabling the EGR through the pcm, there is a write up in the how to section. Hope this helps you
Old Mar 2, 2015 | 09:51 PM
asu11's Avatar
Check with another gauge. Theres probably a leak somewhere. No reason it just randomly starts pulling less vacuum.
Old Mar 6, 2015 | 10:29 AM
mrm95's Avatar
It's also possible that your timing belt jumped a notch. That will throw off the vacuum. That happened to my Civic not too long ago.
