help engine and tranny wont separate
Old Mar 17, 2015 | 05:09 PM
kinein's Avatar
Cannot get the engine and tranny to separate please advise
Old Mar 17, 2015 | 05:27 PM
kinein's Avatar
And yes all the bolts are out
Old Mar 17, 2015 | 06:18 PM
Roadrunr's Avatar
1. Did you already separate the Transfer Case from the Transmission? If not, you will need to remove the left axle shaft from the front differential that is in the Transfer Case. It is on the left side of the Transmission.
2. Did you release the Throughout Bearing from the Pressure Plate?
Old Mar 17, 2015 | 07:39 PM
kinein's Avatar
Did not release the throughout bearing. Im stuck like chuck
Old Mar 17, 2015 | 08:00 PM
Cal City Evo's Avatar
The way they did mine when the clutch was done was take the bolts holding the pressure plate loose from the clutch lever area and it should come right apart.
Old Mar 17, 2015 | 09:02 PM
barneyb's Avatar
Well, do that.
MRak
Mar 12, 2014 06:46 AM
Claudius
Site Feedback / Suggestions
Jun 12, 2003 03:51 PM
