Sponsored by:
Sponsored by: CARiD
AEM Failsafe or separate boost and AFR gauge?
Old Aug 22, 2013 | 10:41 AM
MRak's Avatar
I am trying to decide if I want to run the AEM failsafe for boost and AFR monitoring or if I should go for 2 separate gauges. I find the single gauge setup to be very appealing. Due to the complexity of the set up, I probably wouldnt be using the failsafe mechanism that it offers until a later date. Even still, at $250-$300 it is the same price as buying a decent boost and AFR gauge separately. So my question is, is there any downside to the failsafe? Any bad experiences using it from gauge only standpoint?
Old Aug 22, 2013 | 01:19 PM
Scott@HKSUSA's Avatar
No downside at all. In addition to combining boost & AFR, I really like the way the new TFT center display looks vs. the older LCD displays.
Old Aug 23, 2013 | 06:15 AM
teameditevo08's Avatar
I was debating the same thing before I got mine and decided to go with the failsafe. Im not a big fan of the bunch of gauges thing so it works out. I've yet to try the failsafe feature only hooked up the afr and boost and seems great, and like the guy said above the display look awesome.
Old Aug 23, 2013 | 07:35 AM
MRak's Avatar
ok thanks guys. Im sold. You find any good deals on it anywhere?
Old Aug 23, 2013 | 07:58 AM
IRPerformance's Avatar
Its a great piece of equipment. I run them on a lot of cars. The nice thing is you have both a wideband and boost gauge in one. It can also be integrated with certain ecus to dump boost if the afr's get too lean. I have one on a mazda rx-7 right now with an AEM ecu and have it set to open the wastegate if the afr's get leaner than 12.2 under boost.
Old Aug 23, 2013 | 08:11 AM
TheBoz's Avatar
I have one on my 8 and it is really nice. Because it is a 2 in 1 + data logger, there really are no down sides to it. The display is really nice, much better than the older versions.
Here is a review video I did on mine.
If you hookup your RPM to the gauge, you can also export the logs to VDR.
Old Aug 23, 2013 | 08:29 AM
MRak's Avatar
my main concern is the installation. I am very intimidated by it...
Old Aug 23, 2013 | 06:15 PM
MrJoshua's Avatar
Is it accurate?
Old Aug 24, 2013 | 08:22 AM
Yes same here the boost and afr is simple as any as for the failsafe and everything else i will probably be seeking help
Old Mar 11, 2014 | 04:48 AM
evoyrrah's Avatar
What's the maximum boost these things display?
Old Mar 11, 2014 | 05:14 AM
Evo82's Avatar
30-35? maybe
Old Mar 11, 2014 | 07:21 AM
butters149's Avatar
anyone in socal installed one of these before?
Old Mar 11, 2014 | 02:21 PM
antyoo's Avatar
I bought one, might be doing the install this weekend.
Old Mar 11, 2014 | 09:41 PM
m0nkie's Avatar
this thread got me sold on the AEM wideband. Just purchased one on Amazon..
i hate browsing forums sometimes...
Old Mar 12, 2014 | 03:14 AM
evoyrrah's Avatar
It only reads 2bar! That's not very good of a modded evo
