HKS 264 and 272 mix setup
Old Mar 19, 2004 | 09:57 PM
GokuSSj4's Avatar
why would you just install cams with no cam gears :roll:
264/272 have no problem stalling , friend of mine was running 272/272 with Toda cam gears on stock ecu and no problems either . now he has the P1 with it , which the car pulls alot harder ...
Old Mar 20, 2004 | 01:04 PM
Jadiem's Avatar
i was thinking about just going 264's with hks cam gears... i don't plan on upgrading my turbo anytime soon... but if i do, will the 264's work better than stock with an upgraded turbo? i know they won't out perform 272's...
Old Mar 20, 2004 | 01:19 PM
Shahul X's Avatar
i think 264in/272 ex is the way to go.... no cam gears from what most tell me.... I think the cams will be fine with an upgraded turbos
-Shahul
Old Oct 14, 2007 | 08:33 AM
brucksport's Avatar
why ?? why 264/272 and not 264/264 , and why not go 272/264s ? does anyone have a dyno of these setups so we could compare? an autocrosser may need a different set up to a drag racer, so a little clarity on the choice would help
Old Oct 28, 2007 | 02:26 AM
nasty8evo's Avatar
i love my 272's
Old Oct 28, 2007 | 02:28 PM
brucksport's Avatar
im sure you do,,,,but at what rpm does your powerband come in ? how often do you have to shif gears in daily driving in mild trafic ?
Old Oct 28, 2007 | 02:39 PM
Sxhawnn's Avatar
wow amazing revived from 2004
Old Oct 28, 2007 | 02:56 PM
LT1runner's Avatar
I have a set of HKS 280s and no stalling at all.
Old Oct 28, 2007 | 03:01 PM
JordanS4's Avatar
wow
Old Oct 28, 2007 | 03:17 PM
CrackerJackToy's Avatar
How come ppl never talk about 280/272 setups?
Old Oct 29, 2007 | 05:44 AM
Danner's Avatar
I would imagine anything is better than stock.
264/264 would increase low/mid range
272/272 increase midrange/top end
264/272 would probably be a mix of both.
Old Oct 29, 2007 | 05:56 AM
Evol.ved's Avatar
The art of tuning the EVO has come a long way since 2004.
Now HKS 272's are pretty much the minimum with 280 being more of the norm.
Little to no idle issues with any cams.
Old Oct 29, 2007 | 06:00 PM
brucksport's Avatar
its not only idle quality that causes a concern, what about an auto x situation where you need to rotate the car useing the power at low rpm ? or when driving on the road in normal situations where you need to make a quick pass on the car in front.....the cam does dictate how you drive the car...i think big cams that give big power up top is just for braging rights and bar talk,,,torque and the spread, i think is more important for the street or auto x
Old Oct 29, 2007 | 06:09 PM
4G63 T's Avatar
Its all about tuning
Old Oct 29, 2007 | 09:43 PM
04AWDTURBOEVO's Avatar
Here is my set-up with HKS's 264i and 272e Cams.
Fidanza Cam Gears, both set very negative.
The little Cams can hold the power all the way past Redline, . And, also notice the mid power, .
264i/272e with Cam Gears. Good choice.
They have allways made power for me, even on stock 9.8 Turbo, .
Tuning, also very important, as some have mention.
