turbo problem,need help!
Old Apr 5, 2015 | 02:06 AM
babaz7's Avatar
i installed my new pt6266 turbo in my evo, but when i crank the engine to prime the turbo there is no oil returning from the return line, why is that?
i have a -4 oil feed line and a -10 return line.
Old Apr 8, 2015 | 02:23 AM
babaz7's Avatar
talked to presision turbo, they are reccomending to run the oil feed line through the oil filter housing...
i want to know, do you have to modify the oil filter housing or need any specific parts for it, or do you just plug it in there?
Old Apr 8, 2015 | 10:38 AM
Project_Broke's Avatar
http://store.forcedperformance.net/m...Lancer-TurboHW
FP makes a kit for it, not sure if you can make one yourself or not. It definitely looks like you need some fittings.
Old Apr 8, 2015 | 11:00 AM
meckert's Avatar
Have a look at the filter housing--you will see a recessed allen head plug and a domed cap. Both of these give you access to the filter housing.
Old Apr 8, 2015 | 11:29 AM
STLEVOIX's Avatar
42DD sells the oil filter fitting that will screw into the stock oil filter housing and then you can use a 1/8 npt fitting from there.
Old Apr 9, 2015 | 12:20 AM
babaz7's Avatar
thankyou all!
Old Aug 13, 2016 | 03:30 AM
Sam Barder's Avatar
Deleted. This mobile site sucks somtimes.
CGroovy2k2
Dec 3, 2015 05:54 PM
Shammy
South Region
Feb 26, 2009 02:32 PM
JYoungEVO
Sep 30, 2008 10:01 PM
mungro23
Mar 19, 2008 12:03 PM
Evo#1
Jun 26, 2005 06:46 PM
