South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
Turbo Timer problem "I NEED HELP"
Old Feb 24, 2009 | 09:24 AM
Shammy's Avatar
Ok I have a greddy TT. I have it since the day I bought my car about 3 yrs ago. Well Last weekend I decided to put a system since my evo is slow anyways. All I did is remove the head unit put the RCA jack and nothing else. Now my turbo timer is not working properly. I can set the timer to what I want to but ones I turn off the car and start it the memory I set goes back to zero and it does not time anymore if I drive far or if I rev it a little higher.
So did I pinch some wire that f'd up my tt? did I broke my TT? I don't know what to do? Do I need to buy a new one or can it be fix? Please help!
Old Feb 24, 2009 | 10:00 AM
Evo_Someday's Avatar
I know nothing about the turbo timer - but I would guess you maybe pulled a wire loose or something. Check all the cables to the turbo timer.
Old Feb 24, 2009 | 10:19 AM
Shammy's Avatar
Ok i will try that. Just to throw it out... more weird things happened to my car last night. It start by it self I don't know why lol.
Old Feb 24, 2009 | 12:53 PM
monkey_187's Avatar
Get rid of that greddy, I say that because I KNOW many friends that have had problems with them. Im not just saying it cause I have no clue. Other will say otherwise once they read my post. I would go with an Apexi or HKS, I have owned both and never had a problem with either. I would disconnect it an see if your car still has the same problem. Once you do that you should know exactly whats wrong.....good luck
Old Feb 24, 2009 | 01:18 PM
goofygrin's Avatar
it happened because the turbo timer started your car. Something is not right with the wiring. Did you do the stereo install or did a shop? If a shop did it they messed something up and should fix it. If you did it, well, you get to fix it
Old Feb 25, 2009 | 07:56 AM
Shammy's Avatar
Well I install it so I guess I have to fix it . ThX guys, for now maybe this weekend coz Im busy at work I think I just need to look at all the wiring again and see if I pinch or forgot to connect something. FYI I install the TT too so thats why its probably messing up lol.
Old Feb 26, 2009 | 01:54 PM
Shammy's Avatar
I try checking all the connection and make sure no loose wire, I disconnect and reconnect the plugs but still the same, some how the time memory keeps going back to zero. So anyways I think I'll just go buy the APEXI or HKS just like you said.
Old Feb 26, 2009 | 02:32 PM
monkey_187's Avatar
You will not go wrong with either one they are both great TT. I like the HKS type 1 cause you could use the RPM warning setting like a shift light and it has many other features. This is the only reason why I sitched from the Apexi to the HKS. research wich one would work for you.
I have an extra harness if you need one, its brand new and never opened, makes for a quick install.
