Max power on single walbro 450 pump?
Old Apr 20, 2016 | 09:54 AM
  #31
RazorLab's Avatar
If your riding on the edge, there are companies that sell voltage boosters for the fuel pump. From what I have heard most fuel pumps really improve from increased voltage. I would think increased voltage would especially help at higher line pressure too. I believe some mfg's publish their flow numbers at higher voltages as well.
Yea the 450 HP really excels with higher voltage.
Old Jun 5, 2017 | 10:37 AM
  #32
juanmedina's Avatar
I am planning on switching to E85 and I have HTA Green on stock engine. From my understanding I will probably be making less than 500whp.
The car has a 255lph pump right now and I will be replacing it with a 450lph E85 pump. Will it be ok to run the pump without hard wiring it in my case? I am thinking about getting FIC 1650cc hiz injectors.
Old Jun 5, 2017 | 11:08 AM
  #33
LetsGetThisDone's Avatar
I would not run the walbro 450 on stock wiring. Follow mrfred's rewire guide to maintain the hi/lo voltage function.
Old Jun 5, 2017 | 01:13 PM
  #34
juanmedina's Avatar
Do you have a link? I wish I was a good pump between the 255 and 450 to not have to rewire it.
Old Jun 5, 2017 | 01:19 PM
  #35
R. Mutt's Avatar
Please be aware there are reports coming out from some respective evo shops that recent batches of 450s have been failing. There's likely a bad batch out there. I myself have been running one for 2+ years without issues but if you just grabbed one or are thinking of grabbing one it might be safer to go with a bosch044 or something from Fuel Lab's prodigy lineup.
Old Jun 5, 2017 | 01:45 PM
  #36
https://www.evolutionm.net/forums/ev...e-circuit.html
Old Jul 20, 2017 | 04:11 PM
  #37
turbo addict's Avatar
How are you increasing voltage? Research I have found on the boost-a-pump say that the voltage is too high and they don't recommend using the boost-a-pump with the walbro 450.
Old Jul 20, 2017 | 04:35 PM
  #38
RazorLab's Avatar
I use an easy performance fuel controller
Old Jul 20, 2017 | 06:13 PM
  #39
No problems with it? Looks like a good way to go.
Old Jul 20, 2017 | 07:05 PM
  #40
Abacus's Avatar
I've had good results with a boost a pump or JMS voltage booster on many cars . My current evo has made 650whp on a red. A boost a pump @14Volts Walbro 450 on id1700s at 90% duty . Stock lines, regulator and radium rail on 85% ethanol content on a Dynojet.
I think a few have made 700whp with correct voltage to a 450 pump on ethanol.
The 450 pump is stout for less then 700whp would be my choice with a voltage or pump controller. A single pump is easy to diagnose compared to dual pumps if fuel flow starts to decrease over time.
Old Jul 20, 2017 | 09:31 PM
  #41
RazorLab's Avatar
It worked well for me before my motor went. :-X
Keep in mind, I am using it to power and control a wally 450 in a surge tank. I don't see why it wouldn't work just as well wired to a pump in the OEM tank.
Old Jul 21, 2017 | 04:07 PM
  #42
AWDSeven's Avatar
I run a 450 with FP Black SS FiTronic E85 2000cc IJD upgraded lines and FPR and I am just hitting barely 600whp. Tuner told me something was up with my fuel system even though I did the proper upgrades for the 450. I feel like I can def go more but I guess im happy with 600whp for now
Old Jul 23, 2017 | 08:54 AM
  #43
miragevo's Avatar
Veteran: Navy
2 - 450 Pumps?
Does anyone have any experience with the maximum power possible running 2 - F90000267 Walbro 450LPH E85 Fuel Pumps?
Old Mar 12, 2018 | 10:30 AM
  #44
seven10's Avatar
I followed MrFred's guide to add a hobbs switch for a high current line to my 450, but I seem to be running out of pump around 30psi at 550ish whp dynojet numbers on an FP Red with FIC 1650s. Would the next step be to just do a -6an line from the hardline to rail and drill out the siphon?
Old Mar 13, 2018 | 10:10 AM
  #45
Drilling out the siphons helps control regulator over run. It won't make more power. An aftermarket fuel rail and 6an feed line will help.
