am i the luckiest guy on earth or what??
Old Sep 6, 2015 | 04:41 AM
maikcat's Avatar
good day all,
also posted a few weeks ago about my oil filter became loose and i manage to save it on time until yesterday....
while was returning home with my wife/kids, stopped at a spotlight i noticed
a scratching sound , first i though it came from a car next to me but i was wrong....
after 30sec and while i started moving i noticed the red oil lamp was on
unfortunately i only thought to move right and stopped not turn off car at once,
after 10 sec engine simply blocked.....
aftermath:
the oil pump is connected with the cam timing belt via a gear which is simply attached
to the pump via a screw.....
the screw somehow manages to unbold itself causing the gear to hit the plastic
cover (thats why i heard a noise) after it broke it and fell of the belt was loose
causing my engine sto stall rendering the valves !@#!@!@!@
i dont know until now what the extend of the damage is (i will find in during the week)
maybe i am the luckiest evo owners on the planet earth...
has anyone else heard about a similar case before or i am the number 1 case?
A very sad evo owner,
Michael.
Old Sep 6, 2015 | 05:30 AM
Ev0ikon's Avatar
Sorry to hear that. Who was the last to touched the crank pulley/timing belt area?
Old Sep 6, 2015 | 09:37 AM
maikcat's Avatar
my mechanic replaced both belts & crank pulley but this happened in 4/2012....
the last upgrade work was a bolt on turbo swap 1 year ago.
when changing belts is also oil pump pulley affected?
thank you for your interest.
Michael.
Old Sep 6, 2015 | 12:11 PM
Ev0ikon's Avatar
Yes. It's all connected the the main crank pulley. But it has been a long time ago I can't blame the last installer. What I think you called oil-pump pulley is actually the balance shaft. I have seen so many failed 4G63 due to this balance shaft belt failing and taking out/damage the main timing belt in the process.
Old Oct 19, 2015 | 03:41 AM
maikcat's Avatar
This is what fell of the engine rendering my evo useless...
fenriq007
12
Nov 20, 2008 07:21 PM
