Oil pressure drop at high RPM
Old Sep 14, 2015 | 08:04 PM
Titish's Avatar
Question Oil pressure drop at high RPM
Hello EVOMers
I had a 2.3 L thatspun a bearing lately and before doing that it had a loss of oil pressure after 6k rpm from 105psi to 95psi gradually i tried diffrent oils but it never helped so now i rebuilt the engine...new crank/rods/pistons/oil pump and now the pressure hits 117 psi and drops back gradually to 113..this pressure is too high and i don't know the reason it is still dropping after the rebuild..please help
P.s am using 5w50 oil
Old Sep 15, 2015 | 08:17 AM
LetsGetThisDone's Avatar
The pressure relief opens. You had plenty of oil pressure before the rebuild. Try going to a thinner oil to reduce the pressure in the current build.
Old Sep 15, 2015 | 08:29 AM
Titish's Avatar
So u recommend going 10w40 instead of the current 5w50?
Old Sep 15, 2015 | 11:51 AM
What specs was the motor built to? If it was built within OEM tolerance, use OEM rec'd oil. If you deleted balance shafts, that will also increase pressure. I would try 10w30 and go from there.
Old Sep 15, 2015 | 11:54 AM
Titish's Avatar
It was built to standard specs..everything new and yes balance shaft deleted..switching to a lower grade oil will help with the high pressure but what about the pressure drop at the end of rpm?
Old Sep 15, 2015 | 12:10 PM
The pressure drop is the relief valve opening, reducing flow and pressure.
If you're revving the engine to 8k, good oil pressure at 8k is 90psi.
Old Sep 15, 2015 | 12:11 PM
Titish's Avatar
So keeping on 5w50 and that high pressure will be harmful and u recommend going 10w40
Old Sep 15, 2015 | 12:16 PM
I would try a thinner oil, yes.
Old Sep 15, 2015 | 12:17 PM
Titish's Avatar
Thanks man i will try that
Old Sep 16, 2015 | 07:01 AM
94AWDcoupe's Avatar
is oil pan dented? a dent near pickup can restrict flow
Old Sep 16, 2015 | 11:19 AM
Titish's Avatar
Oil pan is like new
eddy5201314
Jan 25, 2017 08:06 PM
clanzkiller
24
Jun 15, 2014 03:33 AM
211Ratsbud
Nov 11, 2012 01:22 PM
Tainted Winter
Nov 7, 2005 07:49 PM
jbigelow
14
May 3, 2005 08:46 AM
