Walbro 450 Not Getting Power
Old Sep 28, 2015 | 09:17 AM
ReivaXVrai2's Avatar
I hard wired an E85 Walbro 450lph fuel pump into my Evo 8, and the car isn't sending power to it through the harness. Before I installed this upgrade, the car had no issue sending power to the AEM 320lph that was in it before hand. Where should I start looking for an issue?
Old Sep 28, 2015 | 03:43 PM
J_Striker's Avatar
The relay set up you did with your hard wire. Start there.
Old Sep 29, 2015 | 07:59 AM
The relay is getting power from the battery, but not from the harnes. I removed the connections and attached a multi meter to the harness power wire, and it stays at 0 volts.
Old Sep 30, 2015 | 12:42 PM
Update: Figured it out. The pump was simply not priming. It got power when turning the engine over.
xXANCHORMONXx
Apr 5, 2024 01:01 PM
rstchris
45
Mar 13, 2018 10:12 AM
Grip Master
32
Sep 18, 2015 01:09 PM
Boost_Inspired
Mar 26, 2013 07:32 PM
GTSMWET
Midwest Region
13
Jul 28, 2005 01:52 PM
